Custom Search
Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
The Tire Rack- Revolutionizing Tire Buying
Click here for the Best Buy Homepage
Free Shipping at Buy.com!
Cake Batter Muscle Milk, Exclusive Flavor
Bad Credit? No Credit? No Problem!
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Sequoia Alarm Install Help", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Closed Thread
Old 02-09-2005, 07:43 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Gallery
Last Online: Today 10:37 AM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
Default Sequoia Alarm Install Help
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|wht/blue & wht/red |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/red |+ |ignition harness |
| SECOND IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|pink |+ |ignition harness |
| POWER LOCK|see direct fax | | |
| POWER UNLOCK|document #1070 | | |
| LOCK MOTOR|blue/red | |blk plug, pin 1 @ BECU *4 |
| UNLOCK MOTOR|red/black | |blk plug, pin 14 @ BECU *4 |
| DISARM DEFEAT|blue/black | |blk plug, pin 2 @ BECU *4 |
| PARKING LIGHTS +|green | |back of fusebox, 12 pin plug|
| PARKING LIGHTS -|green | |headlight switch |
| HEADLIGHTS|yellow/red |- |headlight switch |
| DOOR TRIGGER|*1 |- |*1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |in back door at ECU |
| HOOD PIN|blue/white |- |DKP, 26 pin plug in pin 4 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|yellow/green *3 |- |ignition harness |
| TACHOMETER|yellow/green | |ECM, 28 pin plug in pin 4 *2|
| SPEED SENSE|green/orange | |ECM, 28 pin plug in pin 5 *2|
| BRAKE WIRE|green/yellow |+ |brake pedal switch |
| HORN TRIGGER|black/yellow |- |steering column |
| WIPERS|blu/blk(L),blu/red(H|+ |steering column |
| LF WINDOW UP/DN|red - green |A |LF window switch |
| RF WINDOW UP/DN|red - green |A |RF window switch |
| LR WINDOW UP/DN|red - green |A |LR window switch |
| RR WINDOW UP/DN|red - green *5 |A |RR window switch |
| SUN RF OPN/CLOSE|not recommended | | |
| RADIO 12V|blue/yellow |+ |radio |
| RADIO GROUND|brown |- |radio |
| RADIO SWITCH|gray |+ |radio |
| RADIO ILLUMINATE|green |+ |radio |
| POWER ANTENNA|white/blue |+ |radio |
| LF SPEAKER|pink - purple | |radio |
| RF SPEAKER|lt. green - blue | |radio |
| LR SPEAKER|black - yellow | |radio |
| RR SPEAKER|red - white | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 The two driver side door trigger wires are in a 14 pin plug in the driver kick panel. The driver door trigger is gray/red in pin 14, the left rear door is red/white in pin 13. The two passenger side door trigger wires are in a 14 pin plug in the passenger kick panel. The front passenger door is lt. green/black in pin 14, and the right rear door is red/white in pin 5. Use all four and diode isolate each. *2 The ECM is behind the glove box. *3 This is the ignition key sense wire. There are 2 yellow/green wires in the ignition harness. The correct one is in a 2 pin plug. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors. *4 The BECU (Body ECU) is above the driver kick panel. *5 To interface with the tailgate window, must runs wires into the tailgate. The up motor wires is pink and the down motor wire is white.
Toyota
Sequoia
2001-2002
Remote Starter Wiring Colors and Notes
Function
DTI Color
Vehicle Color
Location
Start:
Yellow
BLACK/WHITE
IGNITION SWITCH HARNESS *
Ignition #1:
Blue
BLACK/RED
Ignition #2:
Green
BLACK/YELLOW
Ignition #3:
Wht/Blk
Accessory:
White
PINK
Brake Light:
Orange
GREEN/WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
Green
YELLOW/GREEN
AT ECM PIN B4 **
Parking Lights:
Yellow
GREEN (+)
AT JUNCTION BLOCK ON PASSENGER SIDE AT ECM
Headlights:
Yellow
OEM Alarm Disarm:
Brn/Wht
RED/YELLOW (-)
INSIDE OF DRIVER'S DOOR
OEM Alarm Arm:
n/a
Diesel Glow Plug:
Red/Black
Clutch Bypass Wire:
n/a
Notes:
* This vehicle is equipped with a transponder immobilizer system. ** ECM is located behind the glove box on passenger side of the vehicle.
Toyota
Sequoia
2001-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
DTI Color
Vehicle Color
Location
Constant +12 Volts:
Red
WHITE/BLUE
Starter Kill:
Vlt or Wht
BLACK/WHITE
Ignition +12 Volts:
Orange
BLACK/RED
Dome Lights/Superv:
Brown
WHITE
AT BCM PIN B8***
OEM Horn:
Blue
WHITE/RED (-)
DRIVER'S KICK PANEL
Power Lock:
Wht/Red
SEE NOTE ****
Power Unlock:
Yel/Red
SEE NOTE ****
Trunk Release:
Grn/Wht
Alarm Input Wire:
R/W or Gy/Bk
WHITE
AT BCM PIN B8***
Notes:
*** The BCM is located high on the drive's side underneath the dash. Test for correct wire. **** Modern Toyota Door Locks.
WIRE COLOR LOCATION
12 VOLTS CONSTANT WHT/BLU IGNITION SWITCH HARNESS
IGNITION 1 BLK/RED IGNITION SWITCH HARNESS
IGNITION 2 BLK/YEL IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1 PNK IGNITION SWITCH HARNESS
STARTER BLK/WHT DOTS STANDARD IGN HARNESS
PARKING LIGHTS GRN (+) AT JUNCT BLOCK ON PASS SIDE AT ECM
DOMELIGHT WHT AT BCM AT DRIVER'S SIDE UNDER DASH
PWR DOOR LOCK
PWR DOOR UNLOCK
TACH SENSOR YEL/GRN AT ECM
BRAKE GRN/WHT (+) AT BRAKE SWITCH
HORN WHT/RED DRIVER'S KICK PANEL
FACTORY DISARM RED/YEL IN DRIVER'S DOOR
FACTORY ANTI-THEFT TYPE TRANSPONDER
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 03-27-2005, 05:50 AM
nhparrot's Avatar
Door Lock Notes
~Glenn~
Forum Rules
HERE!
Closed Thread
Bookmarks
Similar Threads for: Sequoia Alarm Install Help
INFO: 4Runner Alarm Install Help nhparrot Electrical & Computer Systems 1 03-27-2005 05:49 AM
INFO: Highlander Alarm Install Help nhparrot Electrical & Computer Systems 1 03-27-2005 05:49 AM
Info on Remote Start Alarm Combo??? jdoherty Electrical & Computer Systems 15 10-31-2002 01:37 AM
INFO: Setting 2001 Sequoia Door Lock/Window Features nhparrot Knowledgebase Archive 0 03-23-2002 07:16 AM
TundraSolutions.com and the TundraSolutions.com logo are among the registered trademarks of Tundra Solutions, Inc.
Questions? Please use the Contact Us link or call (559) 323-5444. Other websites: Dealer Hunter JPV Photography
