Old 05-25-2005, 11:34 PM
JUNGLEMAN's Avatar
Dealer : Hanlees Toyota Scion
2005 Toyota Tacoma
Last Online: 04-04-2007 01:36 AM
JUNGLEMAN is on a distinguished road.
JUNGLEMAN's Photo Albums
Default 05 Tacoma-Anyone Added A 2nd Fog Lamp Switch?
So my switch came in today but no pigtail
dealer parts guy shows connectors for every switch BUT fog lamp go figure
now what
it has four tiny flat pins
he wouldn`t let me clip the harness off a truck on the lot
guess I`m off to the wiring diagrams and ..........radio shack???? for connectors or maybe just solder the wires on anyone got a microscope and a pair of tweezers I can borrow?
what was wrong with the previous switches in other year tacos? why did EVERYTHING have to be "all new"?
The list has gotten way too long
http://www.cardomain.com/ride/828118
Old 05-26-2005, 01:06 AM
JUNGLEMAN's Avatar
2005 Toyota Tacoma
I added a pair of KC 6x9`s to the grille guard and want to use a factory fog lamp switch since I have two vacant spots
Everythings wired up and running with a temporary switch
The 05 switch has four pins and I can`t find anything in the wiring diagrams that tells me what goes where
all the switches I`ve ever dealt with have three connections-power in/power to acc/and ground
the fourth connection is probably a headlight power source since the switch is lighted when the headlights are on
Guess I`ll get out the tester light and go to work on the other switch and figure it out.
If anyone can help Thanks
Old 05-28-2005, 02:19 AM
JUNGLEMAN's Avatar
2005 Toyota Tacoma
It is done
Took some detective work but wasn`t too hard to figure out
I modified an unused connector (clutch cancel?) in the dash for the switch, local electronics store had continuity tester and small connectors for testing
Two of the pins are for headlight power in/ground for switch illumination
The other two are power in/out for the relay
Piece of cake
Old 05-28-2005, 08:44 AM
Johnny Law's Avatar
Moderator
Dealer : Toyota Walnut Creek
2005 Toyota Tacoma
Last Online: 11-21-2009 09:39 AM
Johnny Law is on a distinguished road.
Johnny Law's Photo Albums
Can you post a diagram of which pins do what? Even a rough sketch would be helpful.
2005 Tacoma Doublecab TRD Offroad 4X4 shortbed - Modifications - Fog light mod, Debadged, Black Toyota grille emblem, Map Light Mod, DRL mod
Factory Accessories - Tacoma Bedmat, Extra set of D-rings installed in front bed bolts, Extra set of factory tie downs
Optional Options - FilterMag, Fumoto valve, Westin Suregrip running boards w/LED lights, WeatherTech Floorliners, WeatherTech window visor vents, Prestige remote car starter w/keyless entry, SilverStar headlight and turn signal bulbs, Toytek 2" lift, Muth heated signal mirrors, WAAG grille guard (center only, I'm old school), Taillights tinted by JonsTintedTails.com, Anthracite FJ Cruiser wheels w/ 265/75r16 BFGoodrich A/T
Old 05-29-2005, 04:01 AM
JUNGLEMAN's Avatar
2005 Toyota Tacoma
I should have taken pics as I did it but didn`t think about it as this was a three day research,headache, PAIN IN THE BUTT project as the connector for this switch seems not to exist.Luckily my truck has a 4 pin connector behind the dash that wasn`t being used and fit with only minor modifications.
I`ll put up a pic of the switch but until then:
as you look at the open side of the switch with the connector side facing left the two top pins are headlight power in/ground for switch illumination
and the two bottom pins are power in/return for the relay
basically two seperate circuits
hope this helps
we need the connector part #
the #`s off the existing connector were no help
my local dealer is working on his factory rep to come up with a connector for this switch but if anyone has any leads I would appreciate it greatly
btw the wiring diagrams and connector database in this forum were spot-on
exactly what the parts and service departments were showing on their computers
THANKS couldn`t have done it without you
ANTHONY
Old 05-29-2005, 03:29 PM
Dealer : Country Hills Toyota
2005 Toyota Tacoma
Last Online: 07-29-2008 12:43 AM
kendj is on a distinguished road.
kendj's Photo Albums
Default Switch install
How do the switches mount in the dash panel? Are they popped in with clips or something else?
Old 05-30-2005, 12:16 PM
JUNGLEMAN's Avatar
2005 Toyota Tacoma
Yes, there are keepers top and bottom-depress them and out comes switch
Here`s the switch it is inverted from the way it mounts into the dash for visual purposes
the top 2 pins are headlight power in/ground
the bottom 2 are relay power in/return or power in/out to lights if no relay.Be careful these switches are NOT heavy duty I would highly recommend using a relay.
The round thing is a tiny bulb for illuminating the switch
also included a rough sketch of the wiring diagram
and a pic of the connector that dosen`t exist
Old 05-30-2005, 12:47 PM
JUNGLEMAN's Avatar
2005 Toyota Tacoma
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Fog light switch mod (non DRL) question nhparrot Electrical & Computer Systems 2 07-29-2006 08:03 PM
Adding 2nd fog light switch keninsb Electrical & Computer Systems 1 10-23-2004 07:37 PM
Is this the Fog Lamp Switch? unixguru Electrical & Computer Systems 5 07-31-2003 03:47 PM
Fog Light Switch nhparrot Electrical & Computer Systems 0 03-28-2002 01:28 PM
