Thanks for the info. I wasnt sure if you could splice the wires at the transmission or somewhere behind the dash. Splicing behind the dash might be the best option being would be out of the elements.
QUOTE=TwinStop]
http://www.tundrasolutions.com/forum...ator-truspeed/
Use search terms (superlift & or Truspeed) That'll give you some more entries.
4 wires to connect 2 from the back of the tranny I cut the wire and used insulated connectors so I could just unplug the calibrator and plug the wire back together whala back to stock(need to have one male and one female on the original wire for this to work). Just tucked the box behind the kick panel on the drivers side If I need to do any adjusting I just pull it out. I couldn't get mine close with the chart they supply but a GPS and the Mrs helping me only took a couple miles.
[/quote]
