Check Engine Light - Reset question
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: Check Engine Light - Reset question
  1. #1
    Lurking Member ToyoTundra is on a distinguished road. ToyoTundra's Avatar
    Join Date
    Nov 2003
    Location
    Ft. Lauderdale, FL
    Posts
    46
    Liked
    0 times
    Rep Power
    10
    Default Check Engine Light - Reset question
    Hello,
    I already did a search, but it provided various opinions.
    My question is this:
    If a CEL comes on, then you fix the issue, can you clear the ECM (or whatever it's called) by simply disconnecting the battery??? I know it resets the light on the dash, but does it also clear out the error code from the ECM???? Or, will the ECM have to to be cleared using a OBDII(?) tool???
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Assistant Administrator nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,437
    Liked
    11 times
    Rep Power
    1671
    Default Re: Check Engine Light - Reset question
    Quote Originally Posted by ToyoTundra
    Hello,
    Yes disconnecting the battery will work or it will shut iteself off after 3 trips with no codes being registered.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  4. #3
    Join Date
    Nov 2003
    Location
    Ft. Lauderdale, FL
    Posts
    46
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Quote Originally Posted by nhparrot
    If you could explain...... wouldn't it already have registered a code, so even after 3 trips and the CEL goes off the code is still in the memory???
    To confirm: disconnecting the battery WILL reset BOTH the CEL as well as clearing ALL codes in the memory???
  5. #4
    Junior Member jross is on a distinguished road. jross's Avatar
    Join Date
    Jan 2003
    Location
    North Louisiana
    Age
    40
    Posts
    229
    Liked
    0 times
    Rep Power
    11
    I also need an answer to this question.
    My O2 sensor went out and I replaced it myself...saving $200 from what the dealer wanted to replace it.
    However, the CEL is still on. I disconnected the battery, and it worked....momentarily. The next time I started my truck, it came bcak on.
    Dealership wants $80 to reset!!!
  6. #5
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,437
    Liked
    11 times
    Rep Power
    1671
    When a malfunction is first detected, the malfunction is temporarily
    stored in the ECM memory. This is known as 1st trip detection.
    If the ignition switch is turned OFF and then ON again, and
    the same malfunction is detected again, the MIL will illuminate.
    This is known as 2nd trip detection.
    If the malfunction does not reoccur in 3 consecutive trips, the
    MIL goes off automatically but the DTCs remain recorded in the
    ECM memo
    ~Glenn
    Yes I am a pirate!
  7. #6
    Join Date
    Nov 2003
    Location
    Ft. Lauderdale, FL
    Posts
    46
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    ECM memo
    Ok, so assume all that....... HOW do you clear the DTC's from the ECM memory???? Can this be done by disconnecting the battery or do you need an OBDII tool to reset it, ??????? This is the piece I am missing. Thanks!!
  8. #7
    Junior Member Big Black Tundra is on a distinguished road. Big Black Tundra's Avatar
    Join Date
    Feb 2002
    Location
    Austin, TX
    Age
    31
    Posts
    57
    Liked
    0 times
    Rep Power
    12
    i went to the dealer and he told me to turn off engine then put it on the on position but dont start and then hold the trip botton on the odomiter. when it flash twice release then it is reset this works with only 05 model and up i think
    00 Black Tundra limited hand down to bro
    05 white double cab srs tundra
  9. #8
    Rookie sootie is on a distinguished road.
    Join Date
    Oct 2002
    Location
    orlando
    Age
    48
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    Ross there are 4- 02s on the Tundra .....I think they register as left bank- right bank regarding the error codes...so you have a 50-50 chance of replacing the right one. I could be wrong .....but something to consider. Good luck.
  10. #9
    Join Date
    Nov 2003
    Location
    Ft. Lauderdale, FL
    Posts
    46
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Does anyone know for sure what CLEARS the ECM?????
  11. #10
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,437
    Liked
    11 times
    Rep Power
    1671
    Per the service manual it can be done using the Toyota Handheld Tester or by without the tester by:
    Remove the EFI No. 1 and ETCS fuses from the engine room J/B for more than 60 seconds, or disconnect the battery terminal for more than 60 seconds.
    ~Glenn
    Yes I am a pirate!
  12. #11
    Join Date
    Jan 2003
    Location
    North Louisiana
    Age
    40
    Posts
    229
    Liked
    0 times
    Rep Power
    11
    Sootie, The printout from the inspection place told me which sensor was out.
    I will try the whole fuse thing...disconnecting battery didn't work (worked temporarily).
    Thanks guys
  13. #12
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,437
    Liked
    11 times
    Rep Power
    1671
    Quote Originally Posted by jross
    Thanks guys
    If disconnecting the battery did not work, there is something still triggering the MIL, have it read with an OBDII reader to see the code and that will point to the problem.
    ~Glenn
    Yes I am a pirate!
  14. #13
    Rookie ronhohu is on a distinguished road.
    Join Date
    Apr 2006
    Location
    yucaipa
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Try Autozone. Use their ODB II scan tool. The scan tool will let you clear all the codes. And it's FREE.!!!
  15. #14
    Lurking Member TustinTundra will become famous soon enough. TustinTundra will become famous soon enough. TustinTundra will become famous soon enough. TustinTundra will become famous soon enough. TustinTundra will become famous soon enough. TustinTundra will become famous soon enough. TustinTundra will become famous soon enough. TustinTundra's Avatar
    Join Date
    Feb 2005
    Location
    Orange County, CA
    Posts
    21
    Liked
    1 times
    Rep Power
    12
    I hooked up an OBD II from Autozone, but I kept getting a "No Link" error. It would not give me any codes. Does anybody know what is wrong?
    Clear corners w/titanium amber bulbs, Sylvania Silverstar H/L & Fogs, color matched Molly Grill, Gibson Muffler, Hellwig A/S bar, auto dimming mirror w/compass/temp., RS-3000.
  16. #15
    Guest mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch.
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Quote Originally Posted by TustinTundra
    AUTOZONE needs a better tester.
  1. Check Engine Light?
    By vegasgreed in forum Engine & Drivetrain
    Last Post: 08-20-2011, 07:14 AM
  2. Check engine light @ 41,000 miles?????
    By Tundratuff in forum Engine & Drivetrain
    Last Post: 02-27-2006, 08:43 PM
  3. Check Engine light on after plug change
    By Paul Bentson in forum Engine & Drivetrain
    Last Post: 07-08-2005, 06:29 AM
  4. Check Engine Light @ 5000 miles?
    By oldirtyhughes in forum Engine & Drivetrain
    Last Post: 02-20-2004, 05:38 PM
  5. Replies: 53
    Last Post: 01-01-2004, 11:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
