Question about replacement battery
+ Reply to Thread
Results 1 to 5 of 5
Thread: Question about replacement battery
  1. #1
    Join Date
    Apr 2002
    Location
    Midwest
    Age
    42
    Posts
    98
    Liked
    1 times
    Rep Power
    14
    Default Question about replacement battery
    Hi,
    I have a 2001 Tundra V8 4wd LTD, and I'm still using the original factory battery. Other than some leaking a few years ago, it's been reliable, and still cranks good. Since it's 5 years old, I decided to be proactive and went to the dealership to get an identical replacement battery. My original battery was made by GNB, and is rated at 582 cca/ 125 rc, group 24R.
    The new battery is a Toyota brand (True Start or True Guard, can't remember), 575 cca/130 rc, group 24F. Still has the caps to check the acid levels. I bought the new one, since the service guy gave a me a good deal on it, and said it should be a direct replacement. I just wanted to be sure that the new battery will be compatible with our electrical system. Are 24R and 24F batteries interchangeable? Thanks!
    Tundra LTD TRD AC V8 4wd White
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter LGL002's Avatar
    Join Date
    Jan 2003
    Location
    West Fargo, ND
    Age
    74
    Posts
    2,233
    Liked
    14 times
    Images
    17
    Rep Power
    1319
    Default Re: Question about replacement battery
    I believe that they are the same. 24R means the posts +&- are reversed from normal practice whatever that means. 24F I think stands for Ford hence the F because Ford used the reverse post pattern for many years. Not sure why unless they just wanted to be different than GM and Mopar. In my Tundra and Camry the original batteries had the Panasonic label but I'm not sure who actually made them. You're in good shape with your purchase.
    Larry
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  4. #3
    Join Date
    Apr 2002
    Location
    Midwest
    Age
    42
    Posts
    98
    Liked
    1 times
    Rep Power
    14
    Thread Starter
    I appreciate your advice! I'm glad to find out that the dealer wasn't trying to pull a fast one on me. Now I can drive for at least five more years without worrying about the battery (it does have an 84 month waranty though).
  5. #4
    Supporter LifeTech's Avatar
    Join Date
    Sep 2006
    Location
    NYC,NY
    Posts
    2,581
    Liked
    3 times
    Rep Power
    1491
    Panasonic makes the O/E batteries from Japan. You'll have a hard time finding the Factory Panasonic battery... I would not Buy a Toyota replacement battery from a dealer.They are just rebranded by a domestic Battery maker. wow it says "Toyota" Makes no sense at all. They are standard fare Batts at bad price point. I've found that the dealer batteries tend to be old stock. YU DONT want a battery that has been sitting in stock for 6 months or more. And, the warranty is meaningless. Read it well . All the fine print. Not just what the service writer tells yu.
    But there are those that only want Toyota Motor Oil too, and don't know better that it is really Exxon or another co's oil depending on the region where yu live. They think it is "SPECIAL stuff???
    I 'm not telling yu what brand to get, merely telling yu where not to buy. At the dealer. Unless your Toyota 84 mos warranty battery was bought for $40.00 or less. I doubt it.
    I like Interstate Batteries. Great Cust. Service., But that's me. There are other good batts out there.
    Domestic Auto Battery Industry is basically Three Companies that supply rebranded batteries to 30 or more lables. The lable might determine price to the most exent.
  6. #5
    The Friendly Dragon by the Sea Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    51
    Posts
    2,876
    Liked
    183 times
    Images
    45
    Rep Power
    16219
    If I were replacing the stock battery I'd get an ultima red top. I put one in my car and it has been fantastic plus with the spiral wound cells you don't have to worry about acid spills.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Replacement Battery
    By H2O_MAN in forum 1Gen-Tundra
    Last Post: 06-05-2007, 04:36 PM
  2. Battery question for you engineers
    By micmac in forum Tacoma
    Last Post: 08-05-2006, 06:57 PM
  3. Battery Ground Wire Replacement
    By Jack McDermott in forum Electrical & Computer Systems
    Last Post: 03-30-2006, 05:09 AM
  4. Replacement Battery
    By joetrona in forum Electrical & Computer Systems
    Last Post: 10-31-2004, 10:42 AM
  5. HOW-TO: Tundra - Installation of Optima Blue Top Battery w/Stock Battery Tiedown
    By DevinSixtySeven in forum 1Gen-Member Mods, Build Threads, Write-ups
    Last Post: 09-23-2002, 09:44 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
