Old 09-09-2006, 11:34 AM
Dealer : Blackwood Toyota
2003 Toyota Tundra
Last Online: 08-29-2009 03:27 PM
yeepl is on a distinguished road.
yeepl's Photo Albums
Default Wiring Diagram for Rear Bumper Lights
2003 Tundra Stepside. I recently had a set of lights installed in my rear bumper. Also bought a Toyota fog light switch, similar to those on a 2002 Tundra. My 2003 Tundra has the foglight switch on the stalk.
Attached is a pic of the installed, unwired switch. Also, I have attached pics of the rear bumper lights.
I need help with wiring the switch and the lights.
Any help is most appreciated! Thank you.
Wiring Diagram for Rear Bumper Lights-p1010890.jpg   Wiring Diagram for Rear Bumper Lights-p1010891.jpg   Wiring Diagram for Rear Bumper Lights-p1010892.jpg
Old 09-10-2006, 10:50 PM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
Default Re: Wiring Diagram for Rear Bumper Lights
I wired my lights as back up lights and tapped right into the back up light wiring on the trailer plug. Didn't want the wife to leave them on driving in traffic.
Old 09-12-2006, 10:37 PM
tooldud's Avatar
Dealer : Leith Toyota
2003 Toyota Tundra
Last Online: 07-22-2009 10:53 AM
tooldud is on a distinguished road.
tooldud's Photo Albums
Here is the wiring I came up with for those switches.
http://www.dreamshopwoodworks.com/im...0wiring006.pdf
(link fixed, sorry about that)
Tom
03 AC SR5 Silver Sky Metallic
Cab height ARE cap, Westin chrome step bars, tinted front windows 35%, Hella mini foglights under front bumper ,fog lights under the frame to light up the door area, fog lights under rear bumper (factory dash switches for each set of lights),Bedrug, Hellwig swaybar, one-touch window control for both windows,Kenwood DDX-6019 double din dvd unit,2 amps, 2 sets of speakers, 6 disc cd changer,Q-logic sub box, subs, rearview camera, & skid plate.
Freebies: Power outlet mod,fog light mod, map light mod &, debadged.
Hope to add: Chrome bull bar, headest monitors for back seat passengers (daughters)
Waiting for time to install: kicking alarm w/remote start.
My Website
Old 09-14-2006, 03:17 PM
benbeaux's Avatar
Dealer : Toyota of Richardson
2006 Toyota Avalon Desert Sand Mica,
2006 Toyota Tundra Desert Sand Mica DC,
- Other - 2007 Suzuki Burgman
Last Online: 11-03-2009 07:50 PM
Images: 2
benbeaux is on a distinguished road.
benbeaux's Photo Albums
Talking Re: Wiring Diagram for Rear Bumper Lights
Slick install!
I put my relay for my aux lights behind the driver side tail light. Secured up in the left corner of the cavity with a self tapping sheet metal screw. I ran a 15A fused 14 guage wire from the battery to the relay to supply power to the lights. One side of coil is grounded & the other side is connected to the back up light wire at the back of the tail light.
Soon I'll add that foglight switch to my dash & run another wire for select fire.
Here's a relay diagram & tons of other info:
Special Applications with SPDT Relays
Scroll down to "Connecting Additional Devices to the Remote Turn On Wire"
Old 04-17-2007, 05:14 PM
ma717mgte's Avatar
Dealer : Jay Johnson Toyota
2000 Toyota Tundra,
- Other - 87 Supra Turbo Targa
Last Online: 05-25-2009 04:21 AM
Images: 6
ma717mgte is on a distinguished road.
ma717mgte's Photo Albums
I did almost the same thing, but knowing that 2 H3 55w bulbs would pull a load and didnt want to burn down my truck i used a pre made harness w/ relay
drilled and installed 2 H3 lights on back bumper grounded light to the bumper using the fog light mounting bolt, fished part of premade harness through the class 4 trailer hitch then ran wires including the trailer brake blue wire along the frame. all external wires were wrapped in wireloom and ziptied to keep out of the way. the wires were then feed through a body plug at the back of the cab, feed under the driver side kick plates, wires were ziptied in a few spots to keep them out of the way. the relay was mounted behind the driver side garnish after popping it loose and to also gain access to the wire harness feeding through the cab. the Blue trailer brake wire was also routed to the right side of the steering wheel. pulling 1 wire through the wiring harness located to the far right of the cab under the hood the power wire was then hooked up to the relay, and the switch was mounted near where the trailer brake will be installed. i do have pictures that i can post up, as well as post up a single thread with the instructions.
Bristol Va Home Blacksburg Va Hometown
Tundra 00 White AC 4x4 mods: IS Grill, Clear corners, Euro tails, TRD 3rd brake light, Indiglo guages, Prodogy P3 controller, Rear 55w Reverse lights, Polyurethane Rack and Pinion bushings... more to come
Supra 87 Black Turbo Targa Mods: Euro side markers, Eibach springs, Tokico Illumina struts (blown rod)
Supra 87 White Targa non turbo daily driver running!! finshing up small touches now
RS3000 Wiring Diagram Needed calmissile Electrical & Computer Systems 1 01-02-2007 07:21 PM
RS3000 Wiring Diagram Needed calmissile 1Gen-Tacoma 4 12-19-2006 10:35 PM
Wiring Diagram Details For Sequoia? (TS.com have this ??) bretbowman Audio & Stereo 2 02-10-2005 12:18 AM
trailer lights and wiring problems calitundra Towing 2 10-30-2003 09:42 PM
driving lights wiring suggestions nhparrot Electrical & Computer Systems 0 03-28-2002 01:14 PM
