Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Electrical & Computer Systems
Electrical & Computer Systems Details discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Under hood retractable trouble light install...", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-16-2006, 03:22 PM
benbeaux's Avatar
Dealer : Toyota of Richardson
2006 Toyota Avalon Desert Sand Mica,
2006 Toyota Tundra Desert Sand Mica DC
Last Online: Today 10:16 AM
benbeaux is on a distinguished road.
benbeaux's Photo Albums
Default Under hood retractable trouble light install...
So here's the beast I set out to install in my truck. Not that Toyotas break down, but I like to have an under hood light to check the oil & what not on road trips.
The unit is made by Hobbs & is close to what GM had in their trucks up to about 2002 or '03. If you're on a tight budget, these are easy to find in junk yards. I bought 2 of these on fleabay for $30 each.
Installation was easy. I glued it on. Yep, the unit came with mounting tabs & sheetmetal screws, but there wasn't a good way to position it for easy use. The hood support structure consists of uneven members, so drilling & screwing would look kinda goofy, in my opinion.
I cut the 3 mounting tabs off with a dremel & cleaned up what was left with a razor knife. This will allow the unit to hug the support structure & make a cleaner looking install.
I used a sharpie marker to trace around the housing after finding a good spot to mount it. The Elmer's metal & plastic adhesive I used requires that their product be applied to both items to be glued together.
The mounting location & light housing were cleaned with denatured alcohol to remove any grease or crud that would cause a failure of the bond.
Adhesive was liberally applied to the back of the unit along with 2 pieces of double sided tape (red stripes in pic). The tape will hold the unit in place until the adhesive cures. Yeah, duct tape will work, but I don't want to fight it when it has to come off. I don't think painter's tape will hold.
About 3 feet of wire will need to be added to the light's wiring harness in order to be able to reach the battery. I connected my hot wire to the wire I ran to the back of the truck for my auxillary back up lights. I also fused this connect with a 3 amp fuse. The ground was made at my alarm siren bracket. An option is to run the ground wire to a hood pin switch so the light comes on when the hood is raised. I can easily reach up & turn on the light, so I didn't bother to do this. I may add that later...
After the light was installed, I used a coathanger to chase the power wire down the support structure. The exit is the larger hole at the bottom, right corner of the hood. The larger hole allows 3/8 inch wire loom to be shoved in it for a cleaner install.
Here's some finished install pics showing the magnetic base, suction cup mount & that the light reaches to the back bumper.
Bookmarks
Similar Threads for: Under hood retractable trouble light install...
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Tire Pressure Warning Light peak7tiger Corolla Matrix 5 02-05-2007 04:26 PM
PIAA H.P. Super White Bulbs MTTUNDRA Electrical & Computer Systems 30 03-22-2005 04:08 PM
Check light after header install trlsbiker6464 Engine & Drivetrain 5 12-04-2002 12:57 AM
