flashing seatbelt light
+ Reply to Thread
Results 1 to 6 of 6
Thread: flashing seatbelt light
  1. #1
    Lurking Member shawn2 is on a distinguished road. shawn2's Avatar
    Join Date
    Feb 2002
    Location
    Heber Springs, AR
    Age
    40
    Posts
    23
    Liked
    0 times
    Rep Power
    12
    Default flashing seatbelt light
    I had to take out my seat (bench) and installed a amp and satelite receiver underneath it. There are four connectors that I had to disconnect in order to do this, two on each side, one in front and one in back. (Did that confuse you guys enough?) My question is: Can these wires be disconnected in order to stop the flashing seatbelt light? And Will it effect the airbag? I ALWAYS wear my seatbelt but some times I have to put things in the seat next to me and that little passenger light drives me nutts.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member T'sTOY is on a distinguished road.
    Join Date
    Feb 2002
    Location
    Las Vegas, NV
    Posts
    357
    Liked
    0 times
    Rep Power
    12
    You can disconnect the wires and it will stop the blinking light.
    I don't believe it will affect the airbags' operation, but I'm not 100% sure. Asking your service department the next time you're there would be the best way to verify it.
    My understanding is that the blinking light is just a safety reminder intended to alert you to the fact that the airbag switch is "on" and there is someone (or something) in that seat without the seatbelt secured.
    If you never carry a passenger, why not use the key and turn the switch off and just not worry about the light? That way, if you're ever in an accident (which hopefully never happens) and the airbags deploy, your passenger bag won't go off. I believe it still could, or should, deploy if you were to leave the switch on and just disconnect the wiring under the seat.
    Finally, I've had passengers that haven't put their seatbelt on for whatever reason, and the light has been a good reminder for me to ask them to buckle up. To me, their safety is the most important consideration. I just move my stuff from the seat and leave the system active - the way it was intended.
    T
  4. #3
    Rookie ROCKT67 is on a distinguished road. ROCKT67's Avatar
    Join Date
    Oct 2002
    Location
    Lubbock, Texas
    Age
    46
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Exclamation AIRBAGGAGE
    Your air bag system will not work if it is not connected!!
    d/c
  5. #4
    Join Date
    Feb 2002
    Location
    Heber Springs, AR
    Age
    40
    Posts
    23
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    But which wire is for the flashing light and which is for the air bag? Their is one that connects at the front of the seat and one that connects at the rear to the seat belt holder. Common sense says the one to the seat belt will turn off the seat belt light. But someone said that the air bag might go off by disconnecting it. He said that I might want to unhook the battery when I do it. If any one had a Chilton book, maybe they can tell me.
  6. #5
    Join Date
    Oct 2002
    Location
    Lubbock, Texas
    Age
    46
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Lightbulb DEPLOYMENT
    I do not believe it is possible to deploy the airbags by missconnections. There are several redundant systems to prevent that. However I am not sure which plugs go where??
    They should be closely matched in either color scheme or plug
    compatability.
    I have the manuals on the connector, if worse comes to worse, I can maybe fax somethin'
    Let me know
    d/c
  7. #6
    Supporter Rlockyer is on a distinguished road. Rlockyer's Avatar
    Join Date
    Nov 2002
    Location
    CA
    Posts
    1,593
    Liked
    0 times
    Rep Power
    12
    It makes sense that the connector on the seatbelt is the seatbelt-connected sensor and the connector on the seat itself would be the "butt on the seat" sensor.
    Keep in mind though, that it MAY be a failsafe (normally-closed) connection... leaving the front one unplugged may result in the system thinking that there is ALWAYS something (or someone) in the seat since the circuit would then be open.
    Disconnect the front one and try it.
    Once the front one is disconnected, there's no reason for the back one.
    2008 Tacoma 2.7 RC Base
    2003 SR5 TRD V8 <<< Sold 2005
    Better Built toolbox / Limited leather / Power outlet mod / RS3200 Plus / Rebadged w/TRD / Bully Nerf bars / '05 OEM Taillights / Clear corners / Factory Woodgrain kit / Gentex EC Mirror / Gaylord's Toolbox-Lid / MB Overdrives / Muthco Signal Mirrors / Sport Grille / TRD Dual Exhaust / Camry Nav System
Posting Permissions
  • You may not post replies
  • You may not edit your posts
