Originally posted by T'sTOY
I have no idea what they've done with the RS3200 on the '03s, and I'm surprised they went back to (just) a keyless entry option. Have you tried changing the settings or do you have the pamphlet that came with the system? Just curious.
Mine came with keyless only... don't know if it's standard for all or just the SR5. There's no separate pamphlet... I'll have to scan the owner's manual.
Have you tried leadsleads instructions below? How about trying them and letting us know if they work.
I'd try them, but I have no "bottom (light)" button... just lock and unlock on the front and panic on the back.
If I press and hold EITHER button the transmitter's LED flashes, pauses, then flashes again, repeating until I release.
If I press BOTH buttons it only flashes once and stops, so I suspect that it's not transmitting.
Someone else mentioned that they went to the dealer to complain about it and the dealer disconnected it and replaced it with silicone grease and a special plug/cap to protect the contacts.
I'd just prefer a lower volume... I like the feedback that it provides.
