I purchased and installed a set of aftermarket for lights for my 03 Highlander. The fog lights kit provided a three-pin switch (the switch will light up when fog lights are ON) which is ugly and I don't want to use it.
I want to use a Toyota fog lights switch button can be installed at the empty space right next to the left of steering column. I prefer a switch button that can be light-up itself. I found a thread to this link:
Original Fog Light Switch However, the shape of this switch button looks more squarish, the Highlander's button is a bit rounded at corners.
I need help on the correct switch part number and hopefully someone did the same/similar modification can help. I am not a subscribed user so please provide a link that can be used.
Thanks in advance for your help.
