Electrical & Computer SystemsDetails discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Keyless entry and eBay", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Not all 2002 Tundras came with the same alarm system. Some used one remote and others used another remote. I believe it depended on whether the alarm was installed at the factory or was installed at the distribution point or dealer. You need to look at your alarm ECU and find the FCC ID number. This will tell you which remote you need. The FCC ID numbers need to match.
Rick
Black 2002 Limited 4x4
Mods: TRD Supercharger, Boost Guage, Unichip, Clifford AvantGuard 4 Alarm/Remote Start system, Auto Dimming mirror w/compass & temp, Sequoia Power Antenna, Retrax bed cover, Donahoe long travel coilovers, Total Chaos Uniball UCA, Helo Black Maxx 6 wheels w/ 265/70R 16 Michelin LTX/MS tires, Ivan Stewart front bumper cover, TRD headers, TRD dual exhaust, factory LSD, Total Chaos urethane steering rack bushings, Wheelers urethane front swaybar bushings, Helwig rear antisway bar, Goodyear Gatorback serpentine belt, Fumoto engine oil drain valve,Denso IK22 Iridum spark plugs, Eclipse AVN2454 AM/FM/CD/DVD/Navigation system w/ color backup camera, SilverStar headlights and fog lights, WeatherTec in-channel wind/rain deflectors, Ventshade door sill protectors, Toyota hood protector, TracRac sliding rack system with cantilever extension, IPOD integrated with Eclipse AVN2454, PopnLock electric tailgate lock, Sequoia electric condenser fan, Viair 440P portable compressor, ORS manual hub conversion w/Aisin hubs, StubbsWelding SKO rock sliders, 60" hi-lift extreme jack with slider adapter, Odyssey PC1700MJT battery
Coming hopefully - Warn 9.5ti multi-mount transportable winch, ARB lockers front and rear, 4.30 gears
Are you talking about the engine ECU or the alarm ECU. The alarm ECU is what you want. Mine is located behind the instrument cluster and is taped to the steering column. Is this the ECU that you are looking at?
Rick
Pull off the foam that is covering the ECU on the side where the paper sticker is with the numbers you supplied. The FCC information is on the ECU under the foam. Mine reads:
TOYOTA V.I.P. Security System
Electronic Control Unit
