This is a discussion thread titled "Slip Yoke Assembly", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-01-2007, 06:54 PM
Dealer : Lustine Toyota/Dodge
2004 Toyota Tundra
mossman77's Photo Albums
Last Online: Yesterday 08:24 PM
mossman77 is on a distinguished road.
Default Slip Yoke Assembly
Can someone post a pic of a slip yoke assembly for a Tundra? I just had mine replaced (supposedly), under the TSB, but the part that I thought was being replaced, wasn't. I thought the slip yoke assembly was the part that connects the drive shaft to the transmission??
Old 06-01-2007, 10:28 PM
Ando140's Avatar
Dealer : Beechmont Toyota
2002 Toyota Tundra SR5 V8 AC TRD LSD
Ando140's Photo Albums
Last Online: Today 12:15 AM
Ando140 is on a distinguished road.
Default Re: Slip Yoke Assembly
I could be wrong, but I'm pretty sure the slip yoke is at the back of the drive shaft... connects to the rear differential.
Old 06-02-2007, 12:25 AM
integraGSR's Avatar
2005 Toyota Tundra
integraGSR's Photo Albums
Last Online: Yesterday 06:33 PM
integraGSR is on a distinguished road.
try this. i think they call it a "sleeve yoke". but here ya go.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Old 06-02-2007, 09:42 AM
2004 Toyota Tundra
Thanks. That does help. I took a second look at the TSB and my truck and it appears that they indeed replaced the correct part.
Old 06-02-2007, 09:52 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Today 06:24 PM
HOGWILD will become famous soon enough.
That's amazing! that they replaced the correct part, was this not your second attempt at this?
Old 06-08-2007, 08:13 PM
2004 Toyota Tundra
This is the second attempt to fix the leak. The first time I had it in they just replaced the seal, not the assembly. The second time they replaced the yoke assembly. It's all good now.
Old 06-11-2007, 01:00 PM
Dealer : Kerry Toyota
nukehammer's Photo Albums
Last Online: 07-10-2007 11:32 AM
nukehammer is on a distinguished road.
For everyone's edification. On the 2wd truck, the slip yoke is the front of the driveshaft that goes into the transmission. On the 4wd truck, the slip yoke is the "sleeve yoke" that is in the middle part of the driveshaft. Sleeve yoke is a Japanese mis-translation. The rear driveshaft is made by a Japanese company and is imported. The front driveshaft is made by Dana in the U.S. On the new Tundras and Tacomas, Dana makes both.
Old 06-11-2007, 01:04 PM
Oh yeah, forgot to mention. The slip yoke is called the slip yoke because that is where your lateral movement is - it slips. There is only one point on a driveshaft that allows this movement - side note, the centerbearing also has flex in it to allow movement.
Old 07-01-2007, 05:18 PM
2004 Toyota Tundra
Ok, truck has been to the dealer two times now, and I thought the problem was fixed. They have replaced the slip yoke seal and the slip yoke spline, but it is still leaking tranny fluid! Guess I'll be taking it back a third time to have the entire housing replaced. Has anyone else had this problem?
Old 07-01-2007, 05:22 PM
2004 Toyota Tundra
Default Slip Yoke
My '04 2WD Tundra had a tranny leak near the slip yoke assembly (i.e. where the drive shaft meets the transmission). The first time I had it in they replaced the seal, but that didn't fix the problem. Second time they replaced the slip yoke "spline", and I just found that it is still leaking! Guess I'll be taking it back a third time to have the entire assembly replaced. Has anyone else had this problem with their Tundra?
Old 07-02-2007, 11:30 AM
Dealer : Camelback Toyota Scion
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
tempetom's Photo Albums
Last Online: Today 05:46 PM
tempetom is on a distinguished road.
It seems like there should be a transmission seal to seal the shaft coming out of it. I can't see how the spline would enter into this. When I get time, I'll see if I can find the seal on an exploded view in my CD.
Old 07-02-2007, 11:34 AM
2004 Toyota Tundra
Apparently they replaced the seal initially, but that didn't solve the problem, then they replaced the spline. Maybe the old spline damaged the new seal, and they didn't replace the seal again on the second attempt. I should know tomorrow.
Old 07-02-2007, 06:12 PM
2005 Toyota Tundra,
Yeah that could be it. When you said "spline" I didn't realize that the yoke deal had a splined recess on it to mate with the output shaft on the xmission. I did look at the manual and that has to be it; seal or yoke/spline.
Similar Threads for: Slip Yoke Assembly
How much grease in the slip yoke? Pro40Dually Suspension & Axle 2 05-21-2007 08:38 PM
Leaking slip yoke mossman77 1Gen-Tundra 7 05-21-2007 08:46 AM
truck lurches forward when brakes are depressed bbfirebird Engine & Drivetrain 24 09-29-2006 03:50 PM
Slip Yoke = Sleeve Yoke? chenster Suspension & Axle 0 05-30-2005 07:31 PM
Greasing the Slip Yoke swstandring Engine & Drivetrain 2 04-12-2003 02:22 PM
