This is a discussion thread titled "Surging...help!", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Ok, I posted this a year or so ago and never figured it out so here it goes again.
Under load and mostly at steady throttle my truck surges in about 1 sec intervals (power on/ power off). You can't really see it in the tach, but it is very pronounced by the seat of you pants. Mostly in the low to mid 2k'sand under a load, the more load the greater the surge. For the last year I have tried doing things here and there but mostly just dealing with it. Untill i got fed up this week and drove my ECU back up to Jet Performance to have them reflash it. I have taken out the iridum plugs and went back to stock. I have cleaned the MAF sensor and throttle body, changed the fuel filter, and pcv. Serviced the tranny (cleaned the filter) to eliminate that posibility. And the only thing left is the Jet chip. When I explained what its doing to them, they said it shouldn't be the programming, it would be running rich or lean, if there was a problem. And said it sounds like a bad coil pack. I came back threw it back in and it's still doing it. So most likley, not the programming.
So my question is, does this sound right? Has anyone experienced this? What happens when one of the coil packs goes out, and when do they usually? I might just get one of the proscan tools, but might wait till my friend (experienced mech is out of town) returns. He thought it was the programming too. So any ehlp would be great, somtimes a bit of experience is worth a lot of time and money. It might be a "so obvious, it's invisible" thing. Thanks.
I did it!
08' Tundra DC, SB, 5.7, 4x4, Sky Silver 1st new car!
3" Toytec lift in front, Diff drop, Timbren bushings rear (trading out for airbags soon). 305/65/28 BFG A/T's on 18x9 Ultra Magnus, True Flow XDI intake, Prodigy in tow/haul button cubby.
_____________________________________________
Girlfriend got the ol' girl.... (keep her in the fam) 2000 Tundra, AC 4x4 V8, Donahoe LT coils, TC upper arms, TC diff drop spacers, TC steering bushings, sway bar bushings, custom Deaver 11 leaf spring pack, Ride Rite Airbags, Fox shocks on rear, Viar compressor & 1 Gal. tank on frame rail with quick connect, ARB Air Locker, True Flow drop in filter, [/b]Jetchip (bought another ECU, so stock now), [/color][/b]Downey ceramic headers, Custom Y pipe, 40 series Flowmaster, Centric Drilled and Slotted Rotors & Carbon Kevlar Pads, AR 16x8 Teflon Mojave's, 285/75/16 BFG A/T's, Snugtop Extra Vision top, Yakima racks and Space Booster, Brake Controller, PIAA Super Extreme bulbs, Clear Corners, Light bar w/ 2 Hella Rallye 4000 Euro Beam, GMC sierra fog lights in stock location, Optima battery, Sony mp3, powered Alpine speakers, 2-10's in a MTX Thunderform
I did it!
A bad coil pack should set the engine light and/or set a code.
I would also loose the Jet Chip.
Have someone read the codes, they can be "pending" and not set the engine light.
Low fuel pressure will make a vehicle surge and not set a code or engine light. (2000 tundras are known for this)
Dirty fuel filter from a tank of bad fuel or dirty fuel.
CHECK FUEL PRESSURE
Clean the MAF sensor might help
Try dropping the exhaust before the cats, they might be plugging up.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
Just had it checked and it is throwing no codes. He said the O2 sensors were not reacting as fast as they should (lazy). and we were noticing that the Downey headers have the O2 mount bung off to the side and not directly in the flow. But this problem was not evident directly after the header upgrade. He thought fuel pressure too, cause flow was registering good when it was started. He recomended tapping the fuel rail to get a pressure read.
Is this how it's done? What is the correct procedure? Little leary of tapping my fuel rail.
The fuel pump makes total sense. Cause it's only when it needs lots of fuel. I replaced my sending unit and didn't spring for the pump like a jacka!@. There was lots of magnetic particles, and I tried to clean it up as well as possible. BTW, it was doing this before messing with the sending unit. And the tank strap bolt got stripped and I had to re-tap new ones due to tank damage. So I am not looking forward to dropping the tank again.
Don't the pumps just go when they are bad? Or can it be a slow degrade? What about a Walbro?
And next time I am up in Huntington Beach I will bring my ECU and have Jet flash it back to stock. I don't have much faith in them.
I did it!
Does anyone know the right way to check fuel pressure?
I did it!
I have no idea. My mechanic drove my truck the other day and he also felt the surging. He ask me to bring it back to him to keep all day that way he will go over the whole truck starting with fuel and fuel pressure. I will let you know.
Lots of particles in the fuel tank is bad....
Definatley change fuel filter
Damaged tank???? How bad???
Is the fuel pump submerged completley all the time, or does it sit on a dent, which woul move it up and out of the fuel.
Did you get the little hose back on the pump properly when you changed the sending unit. I have seen that hose bleed fuel pressure under load because it wasnt totally secured upin reassembly. (don't ask me how I know) LOL
23 yrs with TOYOTA
K.I.S.S.
The old tanks damage was nowhere near the unit. It is a brand new tank been in for a year now and I am pretty confident on the reassembly. I have changed the fuel filter 2 times, and it just changes, not elimanates the problem. I blew off the magnetic particles on the pump when I changed it, but again did not change anything.
It is so consistent it seems electronic. If you are going up a hill around 2k-2300 rpm it is one second intervals. One full power, one low power, etc.
If you turn a corner uphill and punch it it goes, then delays hard for a second, then full power till its in the 2's. That is the most sporatic it gets.
I am going to Mex for a a couple days, and my mechanic gets back on sunday. So I will see if he will test pressure then. I am real close to telling the dealer to just figure it out. Thanks for all the help, and I will post any findings right away. Hopfully some more good ideas when I check in again.
I did it!
I used an Actron fuel pressure guage that came with a fuel rail adapter that fits our trucks. Here's a link to the album in my gallery showing a few pics of it being used on my engine.
Paul
__________________ Completed Mods:
S&S long tube headers
Brembo rotors
TSB caliper upgrade
Akebono ProAct ceramic pads
Stainless steel braided brake lines
Total Chaos steering rack bushings
Alignment to DJ's specs
Century cap
Line-X
XM Commander satellite radio w/USA Spec dual aux input adapter
Future Mods:
Rearview camera system
Sound deadener
Fusion Drive
Flux Capacitor Control Unit (FCCU)
Paul
Thanks Paul
Hmmmmm, Thanks, for a better explination. I will keep thinking and post any more ideas if I think of any.
Please keep us posted.
23 yrs with TOYOTA
Picasso, Thanks for thr link and the pics. Have to try it out.
I did it!
Haven't had a chance to check the pressure. But a family friend (mechanic) had to borrow the truck. He said the O2 sensors were probably the culprit, if not, that is one more possibilty eliminated. Being that they were not reacting that fast, kinda makes sense. So I might try that out and repost. Sure going to ba an expensive one!
I did it!
