Old 12-18-2002, 08:04 AM
mitchr's Avatar
Dealer : Phil Bachman Toyota
Last Online: 10-28-2009 11:01 AM
mitchr is on a distinguished road.
mitchr's Photo Albums
Default How Much Fluid for Auto Tranny change
I changed the automatic transmission fluid in the v-8 Tundra last night. I checked the "How TO" section here at TS and it said for a simple drain it took 4.2 qts of fluid to refill. My Tundra manual said it took 2.1 qts.? I checked the level of my fluid before I drained it and then drained and measured the fluid that came out and I had drained out approx. 3.5 qts. It took about 3.5 qts. of new fluid to put the level back where it was. Does anyone know what caused the difference? I thought maybe the difference could be in dropping the transmisson pan and cleaning the filter out which would take a little more fluid.
Thanks, Mitch
Old 12-18-2002, 08:32 PM
Dealer : Lake Charles Toyota
2001 Toyota Sequoia
Last Online: 08-15-2009 03:17 PM
doctormdds is on a distinguished road.
doctormdds's Photo Albums
Mitch,
In my Sequoia I also CAREFULLY measured the ATF the first time I drained it. For me, it took 4 quarts to replinish what I drained. It seems as if I've noticed most others also drained and refilled with 4 quarts. I find it very disappointing that the manual shows the drain and refill to take considerably less than what it actually is. Hopefully, others will post and tell us how much fluid drained out of their transmission the FIRST time they changed it. Also, for what it's worth, I simply drain and refill with Mobil 1. Many others have flushed the entitre system but I feel my simple drain and refill with Mobil 1 ATF will keep the transmission trouble free longer than I will keep the vehicle.
Stan
Old 12-18-2002, 11:16 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 11-14-2009 08:18 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
I cant say for sure (I didnt measure) but when I did mine I drained the pan first then did the complete flush. The pan drain apeared to be about 4 quarts though.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 12-21-2002, 08:54 AM
Last Online: 08-26-2003 09:10 AM
junebug is on a distinguished road.
junebug's Photo Albums
4 qts for the pan. I did complete flush and refill at 10k miles and it took 14.5 qts.
Old 09-10-2006, 02:39 PM
ronniesag's Avatar
Dealer : Toyota Town of Stockton
2005 Toyota 4Runner Sport Edition
Last Online: 08-30-2009 01:39 PM
Images: 2
ronniesag is on a distinguished road.
ronniesag's Photo Albums
Default Re: How Much Fluid for Auto Tranny change
safe refill between 4qts - 4.5qts
Old 09-11-2006, 09:00 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra AC V8
Last Online: 10-10-2009 09:59 PM
Tones is on a distinguished road.
Tones's Photo Albums
I also measured mine at 4 quarts. No need to flush with periodic drain and fills. Mobil 1 ATF works great for our early 00-01 models, but later models changed to the T-IV then the WS fluids.
Old 09-12-2006, 12:32 AM
Hugemoose's Avatar
Dealer : Performance Motors Toyota
Last Online: Today 10:41 AM
Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold.
Send a message via AIM to Hugemoose Hugemoose's Photo Albums
Would it be ok to mix the current ATF with Mobil 1 when I do a simple drain and fill? I need to do a simple drain/fill soon but would it be ok to have only 4 quarts of ATF with the rest of the 10 quarts of reagular ATF. Thanks if anybody has the answer
David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
Old 09-12-2006, 02:21 AM
JohnGrosskreutz's Avatar
Dealer : Big Two Toyota & Scion of Chandler
2002 Toyota Tundra
Last Online: 06-07-2008 12:52 PM
JohnGrosskreutz is on a distinguished road.
JohnGrosskreutz's Photo Albums
I was in school last night, and was checking Mitchell On Demand for auto trannies and it basically said that 00-02( did not list 03 on) does NOT use Type IV fluid they use Dexron III and (Dexron II in parenthesis) Has anyone heard otherwise?
Old 09-12-2006, 11:38 AM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
Last Online: Today 10:12 PM
Images: 9
longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light.
longwoodklon's Photo Albums
Consensus on here is yes, it's OK to mix the Mobil1 ATF with the regular ATF. Many people have done it.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
Old 09-12-2006, 12:12 PM
Hugemoose's Avatar
/Mike
Thank you! Now that's one less thing I have to worry about
Old 09-12-2006, 05:59 PM
Tones's Avatar
Yes I agree. It is safe to mix the Mobil 1 with what is already in there and that is exactly what I have done. I do a drain-and-fill every 15-20k miles.
