stripped spark plug????
+ Reply to Thread
Results 1 to 4 of 4
Thread: stripped spark plug????
  1. #1
    Rookie Big Slick is on a distinguished road.
    Join Date
    Jan 2006
    Location
    Harrisburg, PA
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default stripped spark plug????
    I have a 2000 Tundra with 140,000 miles on it. When I changed the plugs last weekend, one of the plugs wasn't tight when I went to remove it. When I installed the new plug, I could give it a full turn after it was finger tight. It is stripped but is snug.
    At this point, I don't think the plug will blow out because I think it's snug enough to hold in there. (the old plug was not tight for some time because there was carbon on the plug boot and the rubber gasket under the coil was degraded.)
    I understand the real fix is a helicoil but my question is this:
    Is there anything I can do to tighten that plug without doing the helicoil? What I need is a high temp loc tite or teflon tape or something like that.
    Is there such a thing? The loctite that I saw at the auto parts store goes to 400 degrees F. Would that work? how hot do the spark plug threads get?
    Any help would be appreciated...
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member tacomaman06 is on the right track. tacomaman06 is on the right track.
    Join Date
    Dec 2006
    Location
    rock hill, sc
    Age
    33
    Posts
    465
    Liked
    0 times
    Rep Power
    7
    Default Re: stripped spark plug????
    i think your gonna be better off in the long run going ahead and doing the helicoil. trust me, the spark plug threads get very hot, and im really not sure that any kind of loctite, and i know teflon tape wont work, is gonna work and be a good fix for ya. your probably much safer with the helicoil.
  4. #3
    Veteran Member Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones's Avatar
    Join Date
    Dec 2005
    Location
    Houston, TX
    Posts
    562
    Liked
    6 times
    Rep Power
    21
    Perhaps you could dab a little JBWeld on the shoulder of the plug. You probably would have to remove the gasket. I don't know how long it would last under those temperatures either. If it did last, it might ruin your head.
  5. #4
    Supporter tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top. tempetom likes to be on top.
    Join Date
    May 2005
    Location
    Tempe, AZ
    Age
    74
    Posts
    1,642
    Liked
    55 times
    Rep Power
    10879
    You might not want to use any sealant that is nonconductive. The plug relies on a very good ground to complete its circuit and firing.
    We had an extensive discussion awhile back about someones head bolt threads stripping and it appears there's another type of insert that might be better than heli-coils. Good luck and I hope the plug doesn't shoot out.
  1. 2003 tundra spark plug recomendation
    By blade in forum 1Gen-Tundra
    Last Post: 10-17-2011, 09:53 AM
  2. synthetic oils - yes or no?
    By nhparrot in forum Engine & Drivetrain
    Last Post: 06-10-2010, 03:43 PM
  3. Stripped spark plug thread
    By smeta in forum Corolla / Matrix
    Last Post: 11-15-2009, 02:00 PM
  4. New Plugs
    Last Post: 10-20-2006, 10:14 PM
  5. Spark Plug Gap Discrepancy
    By MikeT in forum Engine & Drivetrain
    Last Post: 03-04-2006, 05:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
