This is a discussion thread titled "Engine surges 3 times at start up???", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-29-2007, 12:11 PM
Dealer : Martinsville Toyota
2003 Toyota Tundra
Last Online: 12-21-2008 02:56 PM
Gebo is on a distinguished road.
Gebo's Photo Albums
Default Engine surges 3 times at start up???
My '03 Tundra V-8 starts perfectly fine. What sort of irritates me is how it will idle fast, slow down, idle fast, slow down, idle fast and slow down to normal. It only will do each change in idle speed for about 3 seconds. Is this normal?
Old 09-29-2007, 12:26 PM
Gort11's Avatar
Dealer : Lithia Toyota Grand Forks
2009 Toyota Camry SE V6 Barcelona Red
Last Online: 01-02-2009 03:47 PM
Gort11 is on a distinguished road.
Gort11's Photo Albums
Default Re: Engine surges 3 times at start up???
Clean your Throttle Body and your MAF Sensor. Both are probaly dirty.
2009 Camry SE V6, Barcelona Red,Sport Conv,Sport Leather Package,Moonroof Package,Rear lip Spoiler,JBL
"You Can't Fix Stupid"
Old 09-29-2007, 01:33 PM
2003 Toyota Tundra
Gebo's Photo Albums
I just did about 1000 miles ago.
Old 09-29-2007, 05:48 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: Yesterday 09:55 PM
Hi Volt is on a distinguished road.
Hi Volt's Photo Albums
Any other symptoms while driving ? From what you have stated it sounds like your throttle control motor is hunting, possible cause is a vacuum leak, incorrect fuel mixture on startup, or ignition misfire on startup, even the TPS could either be going bad or out of adjustment. Your throttle motor is fighting to control the idle for a couple of seconds causing the surge. Is your AC on during startup ? If so try it off, the AC fast idle may be interferring.
Some ideas anyway.
Old 09-29-2007, 08:24 PM
2003 Toyota Tundra
Gebo's Photo Albums
My AC is always on. I'll try starting it with the AC off and then get back to you. Does yours do this with the AC on?
Old 09-29-2007, 10:54 PM
Hi Volt's Avatar
I usually turn the AC off before parking anyway, so I can't really remember ever noticing it. Running the fan for a minute helps clear the moisture on the fins.
Old 09-30-2007, 05:04 PM
Puffnstuff's Avatar
2006 Toyota Tundra,
- Other -
Last Online: Yesterday 10:21 PM
Puffnstuff is on a distinguished road.
Puffnstuff's Photo Albums
I strongly suspect that you have a vacuum leak. You should start inspecting your vacuum lines for cracks or general looseness.
My DC has: Python 990 Alarm System, Eclipse AVN5500 Navigation System w/80gb ipod & eclipse speakers, Kenwood KAC-X20 Amp, Car Audio Factory Sub box w/Kicker CVT8 subs, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Goodyear Fortera Tripletreds, Hellwig #7700 rear sway bar
Old 09-30-2007, 08:01 PM
2003 Toyota Tundra
Gebo's Photo Albums
Man, when I hear vacuum leak, I start to sweat. A great Fear comes over me! How many vacuum lines should I expect to inspect? 5, 10, 20??? Do they all connect to the engine?
Old 09-30-2007, 08:36 PM
Hi Volt's Avatar
There are surprising few lines on the engine, won't be hard to spot a loose one. All vacuum is generated from the engine so your main concern is the integrity of all lines connecting to the engine. Also make sure your air intake tube clamps are secure as well. On my '01 throttle body there is a vacuum port located under the throttle motor cover. It is not used on my engine just capped. Also check this one as it is hidden.
Bookmarks
Similar Threads for: Engine surges 3 times at start up???
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
5.7 L- How do I change my oil? gordonware Tundra 46 12-21-2007 03:53 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Engine Compartment Washing JIM E Engine & Drivetrain 16 06-18-2007 09:43 AM
Viper remote start install problems mr4x403 1Gen-Tundra 23 01-16-2007 12:17 PM
