Re: Water pump replacement instructions
Hi,
I downloaded the FSM pages, so I think I am all set on the water pump questions. Looks like you need to reinstall the parts while the FIPG is wet and fresh, andy more than 5 minutes and you need to start over.
If anyone has reassembly tips, I'm still interested to hear them.
If not, I'll just reassemble it all based on the FSM and what I learned from disassembly.
Something to note, don't forget the two o-rings (96761-24019 and 96761-35035) and a new thermostat gasket in addition to all of the other parts you need for the job.
Based on the FSM, it looks like it is possible to install the cam seals by hand. Does that fit with what you experienced?
How about the front seal (behind the crankshaft timing pulley)? Do you need the SST? I'm having trouble finding installation instructions in the FSM pages.
Overall, removing the AC compressor is a bit of a pain in the neck, as well as removeing the DS cam cover. Other than that, the disassembly job is pretty straightforward.
Charlie
