This is a discussion thread titled "Sequoia exhaust manifold leak and high $ quote", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 10-05-2007, 03:41 PM
Dealer : Old Mill Toyota
2001 Toyota Sequoia
Last Online: 10-01-2008 09:12 PM
powerg is on a distinguished road.
powerg's Photo Albums
Default Sequoia exhaust manifold leak and high $ quote
I have an exhaust manifold leak on the drivers side of my 2001 Sequoia. I have contacted a few shops for quotes. 2 different shops quoted me around $850 to replace. The said it was about a 7 hour job. The local Toyota dealership was a lot higher. I asked my local shop that does tire work and light vehicle repair. They said it was too much trouble for them to mess with it.
What have other people paid to have the 1 exhaust manifold replaced? Is $850 normal?
I have read on this forum that it should only take 3-4 hours. I do not have the time or space to do this myself so i will have to get the work done at a shop. Can anyone suggest where I might be able to get a decent deal on replacing the manifold.
I look forward to your input.
Old 10-06-2007, 02:08 PM
Puffnstuff's Avatar
2006 Toyota Tundra,
- Other -
Last Online: Today 02:36 PM
Puffnstuff is on a distinguished road.
Puffnstuff's Photo Albums
Default Re: Sequoia exhaust manifold leak and high $ quote
For that price why don't you just get a set of headers?
My DC has: Python 990 Alarm System, Eclipse AVN5500 Navigation System w/80gb ipod & eclipse speakers, Kenwood KAC-X20 Amp, Car Audio Factory Sub box w/Kicker CVT8 subs, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Goodyear Fortera Tripletreds, Hellwig #7700 rear sway bar
Old 10-08-2007, 09:24 AM
2001 Toyota Sequoia
I thought about headers and I asked the 2 shops that gave me the quotes. It would cost me almost 2 times the amount for a set of headers. The labor is 7 hours for 1 side. If I put headers on both sides, then it would be 14 hours labor (per the shops that gave me the quotes) Labor is the biggest part of the quote.
Has anyone had a shop replace the manifold? If so, what is a reasonable price?
Thanks
Old 10-08-2007, 02:12 PM
Dealer : Lipton Toyota Scion
2004 Toyota Tundra
Last Online: 12-04-2008 06:59 PM
tuesdayd is on a distinguished road.
tuesdayd's Photo Albums
Thanks
Wow! 14 hours to install headers. I did my JBA's in less than five hours, and I took my time. Even when I installed the S&S's (they're more work - grinding motor mounts, etc.) it only took me eight. You might consider doing it yourself. It's not that hard, but it does take some patience.
2004 Salsa Red Pearl DC Limited 4x2
Toyota Mods:
Accessory Meter / Leather / LSD / Moonroof / Tow Package / Rear DVD System / 6 Disc Changer / Challenger Step Boards / Carpet Mats / Toyoguard
My Mods:
Debadged / Line-X / Window Tint to Match Rears / Hellwig Anti-Sway Bar / ORW Steering Rack Bushings / RAPS / VSE Subwoofer / USA SPEC iPod Adapter / Pop&Lock Power Tailgate Lock / Unichip / JBA's are back on / Gibson Exhaust
Old 10-08-2007, 03:05 PM
Senior Contributor
Last Online: Today 12:55 AM
Burger Steak & Eggs will become famous soon enough.
Burger Steak & Eggs's Photo Albums
There are quite a few anecdotes about exhaust manifold noises. Mine made a ticking sound from the lower passenger's side at idle. It was most easily heard while at drive thru coffee bars, where the sound could reflect off a solid surface and then find its way to the driver's side window more easily.
I complained about this during the warranty period. The vehicle was tested for leaks with a "smoke machine", but they claimed there were no leaks. Instead, the explanation was that noise from the exhaust rushing through the manifold tubing was to blame, because of the thinness of the tubing. The exhaust gas itself was properly contained within the tubes (i.e. no leak) but the exhaust noise was not fully contained.
I was told this problem is common to Toyota trucks due to the thinness of the factory exhaust manifold tubing. In fact on V6 Tacomas there is a TSB in place and the manifold has been redesigned with thicker metal to help quell the noise. I was also told that in the V8 Tundra application, simply replacing the manifold is no guarantee the noise will go away, since the replacement manifold is also constructed of the same thin metal.
If you have obvious evidence of a leak....black soot traces seen around the seal etc....then of course the manifold must be replaced, but otherwise it should be mentioned that replacing the manifold is unfortunately no guarantee the problem will be solved.
Old 10-09-2007, 08:03 AM
2001 Toyota Sequoia
Thanks for the information. The noise is very load at start up with the engine cold. It will go away in 5-15 minutes after the engine warms up. It is coming from the drivers manifold area. (Both shops have told me it is a manifold leak so I will have to trust their opinion). I will confirm with them that they believe it will solve the problem. That is a lot of money to not "fix" a problem.
Old 10-10-2007, 04:22 PM
ThomasE's Avatar
Dealer : Piercey Toyota Scion
ThomasE is on a distinguished road.
ThomasE's Photo Albums
You should get some more quotes from other shops, there's no way it's going to take a professional mechanic 14 hours to replace the manifolds. When I installed my headers it took me 9 hours, first time ever I've done headers and I did everything slowly. Even JBA instruction sheet says 6hrs to install their headers.
MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
Old 10-11-2007, 08:52 AM
speed25's Avatar
Dealer : Courtesy Toyota Scion of Brandon
2001 Toyota Sequoia
Last Online: Yesterday 08:07 PM
speed25 is on a distinguished road.
speed25's Photo Albums
I agree with the rest of these guys. I installed my own headers with one helper, and we did it in five or six hours if I recall correctly. The exhaust manifolds look like the worst-engineered part of the truck when you compare them to headers!
Badges Removed, Tinted Windows, 10-disk Changer, SSA Headers, K&N Drop-In, Modified Airbox, Synthetic Fluids, Husky Cargo Liner, Blacked out flares and bumpers, AutoPaintGuard Bra.
Old 10-12-2007, 04:21 PM
Dealer : Toyota of Glen Burnie
2002 Toyota Tundra,
- Other - Wife's Nissan Xterra
Last Online: 09-10-2008 07:37 PM
KFlash is on a distinguished road.
KFlash's Photo Albums
Not sure if it would help you or fit your 2001, but I have a used 2002 drivers manifold that is in good shape. Would sell it cheap. You could do it yourself!?
2002 Tundra AC 4x4 Off Road Package - Revtek coil lift with Wheeler's 1.5" AAL. Superlift Truspeed Recalibration unit. Flomaster dual exhaust. Husky floor liners. Hellwig anti sway bar. Xmas Gift 2006 - 3" Perf. Accessories body lift and Gap guards - Installed 1/6/07! New tires in March 2007 - BFG AT 30570r16 on MT Classic IIs. Total Chaos steering bushing kit. Front swaybar bushing kit from Wheelers Offroad. Stubbie 21" antenna. Underdrive pulley installed with NAPA belt. Timing chain replacement and brake job are next!
Bookmarks
