This is a discussion thread titled "Alternator going bad in '91 Toy?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-20-2003, 12:26 PM
Boone's Avatar
Dealer : Toyota of Puyallup
2001 Toyota Sequoia
Last Online: 07-27-2008 06:13 PM
Boone is on a distinguished road.
Boone's Photo Albums
Default Alternator going bad in '91 Toy?
Need some help folks...
I have a 1991 Toy 4x4 V6 with 212K miles. Started her up this morning and the battery and brake dummy lights came/stayed on. I revved it up and the lights went out. Back at idle, they came on again. After driving down the road, they (dummy lights) went off again but I noticed that my dash lights were dim and my voltage guage was around 9. After about 5 minutes of driving my dash lights became bright and the fan kicked in like it wasn't even on in the first place. The voltage guage was in the normal area as well. The dummy lights never came back on. Fan belts were not squealing either. I'm thinking it's the Alternator, thoughts? This happened before and when I took it to shucks, they did a test and they said the system was fine Is the alternator easy to replace in the '91 Toy? Thanks - Dan
Old 01-20-2003, 01:11 PM
Nmerced's Avatar
Dealer : Longo Toyota
2002 Toyota Sequoia
Last Online: 01-05-2009 08:01 PM
Nmerced is on a distinguished road.
Nmerced's Photo Albums
Check the belts again. There are instances where the belt can be loose but not squeal. If this is not the case, you may have a bad alternator or voltage regulator.
Good Luck.
Bert
Old 01-20-2003, 09:59 PM
HotRod8's Avatar
Lifetime Member
Dealer : Stampede Lexus Toyota
2003 Toyota Tundra,
1996 Toyota Corolla DX Plus
Last Online: 12-27-2008 04:07 PM
HotRod8 is on a distinguished road.
HotRod8's Photo Albums
Yes, I had an '89, I think they're pretty much the same. Just remove the air filter box and ducting right up to the throttle body. This will give you lots of room to get at the alternator. You might want to try just replacing the brushes on your old one before you replace the entire alternator though.
Old 01-21-2003, 09:57 AM
Boone's Avatar
2001 Toyota Sequoia
Thanks guys. Of course it didn't happen this morning and all was ok. I'm going to take a look at it this weekend. I'll keep you posted.
Old 01-21-2003, 01:29 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
$130 for a new Bosch replacement alternator
http://www.nobleforeign.com/
Keep checking, you might do better.
Ken
Old 01-23-2003, 06:57 PM
toy4x4boy's Avatar
Dealer : Halterman's Toyota
2003 Toyota 4Runner Sport 4x4 V8,
- Other - 1989 SR5 V6 Xtra Cab
Last Online: 08-19-2008 12:53 PM
toy4x4boy is on a distinguished road.
Send a message via AIM to toy4x4boy toy4x4boy's Photo Albums
Boone,
It sounds exactly like the alternator. Try replacing the brushes, most likely the problem. Also, you may want to try posting on http://66.216.68.23/ubb/ultimatebb.php?ubb=forum;f=11 great BBS there for our older trucks.
Jeff
Me - 1989 Toyota Pickup SR5 V6 Xtra Cab 4x4 5-speed - SAS, flatbed, 37's, too much to list!
2003 Toyota 4Runner Sport 4x4 V8 - stock, for now
Parents - 2001 Toyota Sequoia SR5 4x4 - Limited fog light install, Sequoia all weather mats, stainless liscense plate frames
Old 01-27-2003, 11:34 AM
Boone's Avatar
2001 Toyota Sequoia
Default Replaced the Alternator
I replaced the alternator this weekend without any problems. Everything is running back to normal. Anyway, thank you everyone for your advice and help. I'm not mechanically inclined so doing this was a HUGE accomplishment for me. A friend came over to help and he said the next project is the clutch He's done all that stuff so he'll take the lead on that project. Thanks again guys.
Old 10-10-2006, 08:48 AM
Dealer : McGeorge Toyota
- Other -
Last Online: 08-31-2007 09:12 AM
UR Buddy is on a distinguished road.
UR Buddy's Photo Albums
Question Re: Alternator going bad in '91 Toy?
Is it common with 91 Toyota's that the brake light appears with the charge light when the alternator goes bad
Bookmarks
