I've been trying to diagnose sudden poor engine performance, that includes engine vibration, since getting a dealership oil change back in May of last year (2006). The long story about that is in
this thread.
After previously discovering and correcting a clogged fuel filter and a leaky PCV valve grommet, I recently discovered that the coil pack over cylinder #8 had partially failed, a state it has probably been in since the dealership oil change from 18 months ago. This was unexpected as I have heard virtually nothing of partially failed coil packs and their symptoms.
I had just completed the 90K maintenance items, except for the timing belt, and the engine still had the same symptoms, namely vibration at idle and highway speeds and a strange pulsing exhaust. The readings on my recently purchased scan tool showed no indications of any problem except for a P0430 (low catalyst efficiency, bank 2) which had started a few days before doing the 90k maintenance. I took a close look at the O2 sensors with the scan tool and didn't find any sign that they were faulty. There were no detected misfires and the plugs that I had just removed all looked the same, which offered no clues.
The only thing that I hadn't touched were the coil packs, so I swapped coils 6, and 8 with coils 5, and 7. Low and behold I suddenly got a pending P0420 (low catalyst efficiency, bank 1) after one short highway drive. The vibration at idle was still there but was now at a different RPM. Moved coil 8 back to its original cylinder and no more P0420.
Replacement of coil 8 resulted in significant reduction of the engine vibration at idle as well as at highway speeds. The pulsing exhaust at idle is now gone. The seat of the pants dyno tells me that torque has improved too.
I'm not certain why a partially failed coil would cause a P0420/P0430 but all of my cylinders looked like a 10 year old campground charcoal grill when I shined a light through the spark plug holes. The plugs that I pulled are much darker than the ones pulled 30k miles ago. Both sets are NGK BKR6EYA - V groove copper cores. Could it be the substantial carbon build up with the bad coil that caused the trouble code?
I did a Techron treatment in my last tank of gas and am doing a BG44K in my current one in an attempt to clean up the carbon. Hopefully this will take me the rest of the way in eliminating the remaining symptoms.
Just thought I would offer this insight to the board. Would also like to hear anyone else's thoughts on what is going on regarding the partially failed coil pack and the P0420/P0430. Anyone else experience something similar?
Paul
PS: The new Denso coil pack has a different part number from the ones that were stock on my 2000.
Original Part #: 90919-02230
New Part #: 90080-19027
