2000 Tundra-Where's The Thermostat
+ Reply to Thread
Results 1 to 5 of 5
Thread: 2000 Tundra-Where's The Thermostat
  1. #1
    Rookie Jasper0 is on a distinguished road.
    Join Date
    Sep 2006
    Location
    Canada
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default 2000 Tundra-Where's The Thermostat
    Just wondering where it's located and how hard it is to replace.
    2000 Toyota Tundra V8
    Thanks,
    -=Jasper=-
    2004 Toyota Tundra TRD 4X4
    2006 Honda CRV SE
    2006 Bombardier Renegade 800HO
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member drewbush is on a distinguished road. drewbush's Avatar
    Join Date
    Jan 2004
    Location
    Redondo Beach
    Posts
    155
    Liked
    0 times
    Rep Power
    10
    Default Re: 2000 Tundra-Where's The Thermostat
    just follow the upper radiator hose to where it attaches to the engine. Three 10mm bolts hold down the housing. you will want to drain a little coolant out before removing it.
  4. #3
    Junior Member ddvk is on the right track. ddvk is on the right track.
    Join Date
    Oct 2006
    Location
    Austin, TX
    Age
    39
    Posts
    477
    Liked
    1 times
    Rep Power
    7
    I was following your other thread regarding tranny fluid and tranny problems. I will do the following, buy new radiator, thermostat and good Hayden heavy duty ATF cooler.
    1) Drain the radiator and block of coolant.
    2) Replace thermostat and possibly the upper and lower radiator hoses along with the pressure clamps if you have money to do the job thoroughly.
    3) Flush the radiator with fresh Toyota coolant.
    4) Install a new Hayden cooler for the ATF, there must be enough space to install it and hook up the return line in series with the cooling from the radiator.
    5) Flush the entire tranny and TC with fresh ATF.
    Then only go into investing $2500 on the tranny.
  5. #4
    Rookie rwhip is on a distinguished road.
    Join Date
    Feb 2008
    Location
    Gardnerville NV
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by drewbush View Post
    I know this is a little late, but I thought I'd add to this based on my experience with my 2000 Tundra V8 (2UZFE engine).
    I found the thermostat in my truck by following the bottom radiator hose. The hose was connected to a die-cast part with 3 screws (I used a 12mm socket that is now somewhere in the skid plate). I had to remove the hose to get to the bottom screw.
  6. #5
    SAS'ed #5 dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim likes to be on top. dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    34
    Posts
    6,226
    Liked
    150 times
    Images
    119
    Rep Power
    11613
    This should help.
    Attached Thumbnails Attached Thumbnails 2000 Tundra-Where's The Thermostat-cooling-2uz-fe-thermostat.jpg   2000 Tundra-Where's The Thermostat-cooling-5vz-fe-water-pump.jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
