This is a discussion thread titled "Question for 2005 and newer Tundras - transmission oil sampling", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Hello everyone,
I'm fond of analyzing the lubricating oils of my vehicles - I have my engine oil, transmission oil, and even differential/transfer case/antifreeze fluids analyzed on occasion.
Samples are easy to take - I have thin plastic tubes, and a small hand-pump that extracts a few ounces into a sample container that I then send to a lab.
However, with my 2006 Tundra Limited Double-Cab 4WD, it presents a problem, since the transmission has no dipstick tube. So - my question is, how should I take a sample?
I have three choices:
1) Remove one of the rubber hoses under the engine compartment that connects the transmission to the coolers.
2) Remove the drain plug on the transmission, and take a sample while the fluid in the pan drains out.
3) Use the "Overflow" "check" tube which only drains fluid when it is above a certain level.
Of the three methods - I think I prefer the third one, if it will work - for two reasons:
a) It doesn't draw fluid from the bottom of the pan - it only takes fluid that is sitting at a high level in the pan, so it avoids getting any sediment from the bottom of the pan that would skew the analysis results.
b) It avoids draining all the fluid - presumably, it would only allow a few ounces to drain, which is all I need for a sample. I don't want to change the fluid at this time anyway.
Thoughts? Opinions? I hate these "No dipstick" transmissions!
Re: Question for 2005 and newer Tundras - transmission oil sampling
If you check it regularly, you might consider finding out if there is a Fumoto drain valve that fits the tranny.
I use them on my vehicles oil pans to sample and drain. No tools required to open and close the valve.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, TRD air filter, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner, DLS Nobelium components and coaxials, TRU 2-channel amp, 13" eD sub, eD Nine.1 amp, iPod hookup. SilverStar lamps.
#3 cause that is the way to check it to start with and refill it with approx 1/2 Quart or the same amount that came out? make sure ya do it per FSM! i will just change mine at 50K along with spark plugs, anti-freeze, 100K is just too many miles to me for any of this stuff!! never hurts to be proactive!! 50K on WS ATF should be changed anyway IMO!!
