This is a discussion thread titled "Another ATF/Mobil 1 Questions", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-15-2007, 04:07 AM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: Today 02:34 AM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Default Another ATF/Mobil 1 Questions
Researched both here and the Mobil 1 site for whether the Mobile 1 ATF labeled "Multi-Vehicle Forumula" and "Mercon V" is compatible with my 02' V8.
What's the story here? Is it or is it not. From what I've read, some say yes, some say no. Mobile says yes, but no where in their labeling does it mention Toyota.
Also, if yes, it is compatible, how many of you out there use it?
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
Old 12-15-2007, 09:35 AM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
Last Online: Yesterday 01:28 PM
ddvk is on a distinguished road.
ddvk's Photo Albums
Default Re: Another ATF/Mobil 1 Questions
Yup, M1 does not say which vehicles it is recommended for other than it is compatible with DexronIII/Mercon and MerconV. It leaves the rest to imagination of the user, which actually sucks.
If you are intent to switch to syn, then shell out a little more and go the Amsoil Universal ATF or shell a little less and go with Castrol MV Import ATF which is clearly labelled to be T-IV compatible.
Old 12-15-2007, 11:45 AM
2XOverhead's Avatar
Moderator
Problem is, I already bought the M1. DexIII is recommeded for my 02, so does that mean the M1 "Mercon V" is compatible?
Coming Soon?
Old 12-15-2007, 12:37 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 06:26 PM
HOGWILD will become famous soon enough. HOGWILD will become famous soon enough.
HOGWILD's Photo Albums
read the article, it says it is ok for Dex2 or Dex3 applications? what is confusing about that?
Mobil Multi-Vehicle ATF
i do not use it cause my tranny uses WS ATF but if i had your application i would use it and quite worrying about it and change it not mix it!! Mobil Oil makes quality products plus you can call and talk to an Engineer that will answer all questions 1-800-662-4525 plus they are priced where they do not empty your wallet!!
More inifo for thought: DEXRON - Wikipedia, the free encyclopedia
Old 12-17-2007, 02:21 AM
2XOverhead's Avatar
Moderator
This is actually the one I bought.
Mobil 1 Synthetic ATF
Yeh, bit paranoid about using the right ATF. After reading the literature in the above link, I'm finally at ease.
Thanks for the reply.
Rich
Coming Soon?
Old 12-17-2007, 12:38 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
I would call and ask Mobil on this type cause its different than the one i spoke of. really need to read application carefully and when in doubt i would call Mobil, they will not try and sell you or have you use a product that will mess up your tranny! and you need to put the correct ATF in it cause they had a lotta problems with consumers and even dealerships messing this up!! results were tranny failures due to improper service!
Old 12-17-2007, 03:37 PM
Dealer : Kings Toyota
2001 Toyota Sequoia
Last Online: 12-19-2008 09:27 AM
guyaverage is on a distinguished road.
guyaverage's Photo Albums
Thats the one I used (with the Mercon V label) for a 16 qt. complete flush about 6 months ago. Shifts smooth as silk, even in very cold weather (mid-teens).
I just did a 5k mile 4qt drain and fill about a week ago and the 4 qts came out so clean and clear it felt like a total waste of time and money (dealer warranty, I had to, to keep the warranty going). If I could pour it 1 inch thick on top of newspaper I would still be able to read the print, it was that clear. Good stuff.
Old 12-17-2007, 06:32 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
the one i mentioned said down near the bottom of article DexII & DexIII ? both i guess would work but i would still cal Mobil , they are customer friendly to the max! the one yall used does not say Dex II which i think was oem in your manual?
Old 12-23-2007, 07:28 PM
LifeTech's Avatar
Slummin'
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 01-06-2009 03:25 PM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Mobil 3309 ATF( It's not a synthetic.) or Toyota Type T-IV for a full flush or if just a drain pan/ then refill I would go with the Toyota Type T-IV.
I'm fussy about staying with the Toy.T-IV though while under warranty.
After that I would consider alternatives. But I really don't trust Universal ATF' alternatives with Aisin Trannies. Just from experience.
One of the few OE fluids I choose to stay with. T-IV is unique...I also won't say it is the best though in durability . UOA's have shown this.
If it was T-II/III, that would be another story. But T-IV seems to be a different animal. And is not even backwards compatible to anything. Some will counter this.
There was a TSB on this. It also discussed the WS ATF which IS a synthetic and also very different.
I do feel that the Mobil 3309 is certified to Aisin-Werner specs and is ok as an aftermarket alternative. Many Trannie shops are using the 3309. I believe the Toyota Type is equal if not cheaper to get.
I believe Aisin-Werner created the T-IV spec in the first place.(with Toyotas guidance)
I know many are using Other Synthetic ATF alternatives with success, and I cannot dispute the pos. results.
You be the judge.
LT
Old 12-23-2007, 07:53 PM
LifeTech's Avatar
Slummin'
Any ATF that's labled as ok for a Ford Mercon "x" along with a Toyota Type T-"x" is bad for either types of Trannies.
The qualities of both specs simply cannot be ideally achieved in a universal package.
I have asked this so many times at many rebuilder shops.
Dealers generally don't know or understand transmissions, short of doing a replacement or service. Dealers never rebuild them. This is just Industry practice.
Only a rebuilder will understand how a specific fluid will interact with a specific trans. It's almost always about the clutches and pressure design.
Has anyone noticed ExxonMobil has many different types of ATF's?
There's a reason...
Again, yu be the judge.
LT
Old 12-23-2007, 08:05 PM
LifeTech's Avatar
Slummin'
I am trying to find the subcontractor for Toyota's Type T-IV.
In any event, we all agree that Toyota does not make this stuff!!
I'm sure it is a trade secret though.
LT
Old 12-24-2007, 01:45 AM
2XOverhead's Avatar
Moderator
I'm thinking that Mobil 1 full synthetic would be ok, especially b/c I intend to change the ATF pretty regularly (every other oil change) after a good pan and filter cleaning and flush.
You make a pretty interesting point. Instead of the 3309, what do you think about Mobil 1's synthetic ATF for the Tundra?
Coming Soon?
Old 12-24-2007, 02:18 AM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: Yesterday 04:11 PM
kathyricks's Photo Albums
rich29_cal, what fluid does your owners manual specify? If you don't have the manual. then your transmission fluid dipstick will be engraved with the correct fluid to use (look halfway down the length of the dipstick)
If your manual says to use Dexron II or III then Mobil Synthetic ATF can be used. If your manual says to use Toyota Type T-IV then Mobil Synthetic ATF cannot be used.
I have 14 years experience using Mobil Synthetic ATF and I have found it turns dark just as fast as conventional Dexron fluid and there is just as much wear debris in my transmission oil pan compared to compared to conventional Dexron fluid. I was naive 14 years ago so I bought into the synthetic hype and didn't fully realize Mobil never directly claimed use of synthetic would increase transmission life 1%, 10%, 50% etc.
Now I realize Mobil used SUBLIMINAL pursuasion; i.e. terminology that gets the public to IMAGINE synthetics substantially increase transmission life.
Old 12-24-2007, 02:56 PM
2XOverhead's Avatar
Moderator
I get your point KathyR. They way I figure it: can't be worse than conventional oil. It's no secret I know, service interval is just as, if not more, important than type of oil. That being said, I get a warmer feeling using syn. I guess you can say the ads are working on me.
