Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "99 toyota tacoma hesitation at low rpm", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-17-2007, 11:04 PM
Dealer : David Maus Toyota Scion
1999 Toyota Tacoma
aquabluepoolsfl's Photo Albums
Last Online: 01-03-2008 04:21 PM
aquabluepoolsfl is on a distinguished road.
Default 99 toyota tacoma hesitation at low rpm
I have a 1999 tacome 2.4 automatic that sputters at lower rpms not all the time but pretty often. Enough to not want to pull ut in traffic. No codes came up I have had it plugged into a dealer style reader drove it around and everytimg seemed normal. I have replaced the MAF, coils,crank sensor,fuel filter, cleaned low idle air circuit, cleaned and inspected injectors,spark plugsand it seems to have this problem. I am running out of ideas now I am down to it may sound funey buy every time it seems like the fuel pressure is taken off the system for a bit then everything is put back together it seems to run its best. just a thought
Old 12-18-2007, 11:23 AM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
ddvk's Photo Albums
Last Online: 09-29-2008 04:42 PM
ddvk is on a distinguished road.
Default Re: 99 toyota tacoma hesitation at low rpm
How many miles on the odometer and when was the last time the tranny/manual fluid exchanged?
Old 12-18-2007, 12:01 PM
Dealer : Performance Toyota Memphis
2004 Toyota Tundra
buglao's Photo Albums
Last Online: Today 10:04 AM
buglao is on a distinguished road.
Try new PCV valve, it is cheap ($3.00 @ Autozone) but cure your problem. I think your PCV valve it clogged. Your truck will run better with new PCV valve.
Old 12-18-2007, 03:42 PM
1999 Toyota Tacoma
The truck only has 50,000 miles on it this is why this problem is so strange. I picked it up at a towing recovery lot. It appears that someone has changed the tranny fluid due to the nasty orange high temp silicone on the pan. I think they thought that that was the problem. Another strange thin is when it is sputtering and you pop it in neutral at with out letting off the gas it's like it never happened but when right back into drive still the same thing. I have even rode around with a fuel pressure gauge on it to see if that was dropping while it was acting up.
Old 12-18-2007, 08:01 PM
1999 Toyota Tacoma
not the pcv valve tryed that
Old 12-18-2007, 08:46 PM
v6er's Avatar
Dealer : Brown's Charlottesville Toyota
v6er's Photo Albums
Last Online: 06-11-2008 03:52 PM
v6er is on a distinguished road.
Wow thats alot of money to spend without knowing whats wrong. Check for vacuum leaks like disconnected lines and stuff. If you find nothing its possible your EVAP canister purge solenoid is stuck open causing a lean A/F mixture.
"The glass isnt half empty or half full...
its twice as tall as it needs to be"
~How an engineer views life
Old 12-18-2007, 09:32 PM
1999 Toyota Tacoma
tell me about it. I have checked for vacuum leaks sprayed almost everything down with carb cleaner when it was running and no idle changes. as for the evap canister purge solenoid how can I locate this and can it be fixed without replacing it?
Old 12-18-2007, 09:43 PM
v6er's Avatar
v6er's Photo Albums
is it a 5vzfe V6?
Old 12-18-2007, 09:58 PM
1999 Toyota Tacoma
it is a 2.4
Old 12-18-2007, 10:13 PM
v6er's Avatar
v6er's Photo Albums
oh well i dont know exactly where it is on that. but if you can find it, take it off and try to blow through it. You shouldnt be able too. If you can blow through it than its probobly your problem.
Old 12-18-2007, 10:19 PM
1999 Toyota Tacoma
i'll give it a try but I am still up for suggestions I need to find a toyota mechanic this has got to be a common problem it so stupid. This is gotta be the reason why these people dumped this truck for 1500 cause no one could figure it out need major help
Old 12-18-2007, 10:33 PM
v6er's Avatar
v6er's Photo Albums
I'm gonna look around on All-Data tommarow, I'll get back to you if I figure anything out.
Old 12-18-2007, 10:49 PM
1999 Toyota Tacoma
thanks man my next replacements are the tps and the plug wires
Old 12-18-2007, 10:52 PM
1999 Toyota Tacoma
well I think I found the evap solenoid it has one tube on one side and to one the other when I blow through the one tube air come out of one of the other tubes.
Old 12-18-2007, 11:04 PM
v6er's Avatar
v6er's Photo Albums
just one? Thats probobly the vent solenoid. thats supposed to always be open, it brings in fresh air. Thats great that you found that so quickly, I think we might be able to eliminate the purge solenoid as a possiblilty. But please dont replace the TPS and plug wires unless its the problem.
