I'm looking for a used Tundra. Does anyone know where I could find specs for the 2000 Tundra 4x4 Access cab? Are there major differences with the 2003 model? Are there any issues on the 2000 Tundra I should be aware of before I buy?
I recently bought a used 2000 Tundra SR5,
I love it, but
I'm curious as to where I can find
a listing of its specs. that the dealer could not provide.
Looking for Horsepower, Torque, MPG, basic stuff,
so I know what can/should be modified.
Any help I'd appreciate, thanks.
I'll take some pics when it doesn't look like a giant iceberg, flyin' down the highway.
Thanks for the link... SATundra, but I was looking for more customized information on my model, like I said I bought it used, so I'm trying to
figure out what if any mods were done to it, cuz the steering alignment blows.
Looking for more performance info on 2000 4x4 Sr5 Access Cab model
and advice on exhaust/filter kits, tires, interior/exterior mods, anything to make
it look and perform better.
Thanks though.
- Diz
Originally posted by hovisimo exhaust and filter kits won't give you any more hp on the V8, after almost 3 years i've concluded there really isn't any way to add power to the iforce V8 other than get the s/c, or to a lesser extent, some engine work involving underdrive pulleys, aftermarket ecu, etc. as far as tires,
That’s not necessarily true you know. Read No Loss in any power to date with mods. and see what this guy found with a simple exhaust upgrade and air box modification.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
208 HP @ 4800 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM Bone stock
Dyno run results click here
ehhh i doubt it's a 20 hp gain. i installed a K&N drop in and true duals and didn't notice any gain, and i lost a little torque. the fact that he kept the resonator and used smaller pipe prevented him from losing torque.
*your milage may vay*
The fact that his 1/4-mile went down from 16.2 to 15.2 at 2000 feet is proof that his truck has an improvement in both torque and horsepower. He even said his truck will more readily spin the tires from a stop than before again supporting that he gained low-end torque as well. What he did differently was he modified the air box inlet tube and like you said used smaller pipe for the dual exhaust along with a higher flow muffler.
I myself lost a significant amount of low-end torque with the TRD duals, which have two 2.25" pipes from a glass packed type muffler. It was enough of a difference for me to not be able to spin my tires in any situation even in a turn. I can readily light them up now if I wanted to in a turn with the stock exhaust system. I don’t have the TRD duals anymore!
stock exhaust
TRD LSD
220 HP @ 4800 RPM
208 HP @ 4800 RPM
204 HP @ 4800 RPM
Don't buy a 2000!!! This first model year is a lemon!!! Be prepared for guaranteed 02 sensor replacements plus all the other nuisance stuff such as the seat belts, antenna, etc. I lost a power steering pump & rack-and-pinion at 358 miles. After that it's been downhill!
A number of us have 2000 model years (myself included) with few to no problems.
Genthar
Some people should not be allowed access to tools without books!!!
Brake vibration that could never be cured for long
O2 sensor failure about every 50K
exhaust manifolds cracked (put on JBA)
bad Mass Air Flow sensor at 80K (due to K&N?)
broke the spider gears in the rear end at 80K (I think due to driving truck 2000 miles home with a bad MAF)
Over all that was the best truck I have ever had, so I bought a 2005
2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
Other than replacing the O2 sensors (which took me about 15 min), no issues at all. It beats the '98 chevy I had which required numerous seal replacements, windshield wipers with a mind of its own, and reclining handles that broke six times.
A lemon? Hardly.
One replaced O2 sensor (+ headers for $450, but that's a mod, not req'd)
- $xxxx.xx (I'd argue this amount is same/similar for any 4wd tundra or any truck for that matter)
Upgraded front brake pads and turned rotors to remove slight glazing of rotors hauling a big load over Tioga pass...
- $125
~ 117k miles.
You do the math. I will be honest that small issues like the weak door checks, weak seat belt retractors and horn could be better. But to call a great, reliable, smooth running truck a lemon for such things seems over the top to me.
I will be honest and say I probably would have gone with an 01 or newer for the above reasons. The only other reason I'd consider 01 and newer? color-keyed tailgate handle (mine's black). But my '00 is no lemon. It's a great truck!
- JD 2000 Toyota Tundra Limited 4x4 w/ TRD Package
Thunder Grey Metallic
Factory Options: Leather Captain's Chairs, Color Keyed Running Boards, tow package Aftermarket Additions: JVC KDSHX900 w/ HD, Sirius S50 Satellite Radio, JL Audio Stealthbox, Eclipse 500W 5-channel Amp, MB Quart Ref Components w/ 1.5" tweeters up front, Coax rears, Peel & Seal sound deadening, Trenz Billet Grill, Tailgate Extender, Sylvania Silverstar headlights, Hella SuperTone Twin Horns, Ivan Stewart Body kit Modifications: Unichip with custom tune, JBA Titanium coated headers, Hellwig Anti-Sway Bar, TRD Dual Side Exit Exhaust, Powertraxx No-Slip, TRD IS Wheels Polished and Powdercoated Gunmetal Grey, shod w/ 285/75R16 Michelin LTX A/T2, Fabtech Performance Coil-overs & Donahoe Racing leaf springs with bilstein 5100, Rear Porterfield Carbon Kevlar Shoes with cryo-treated drums, Power Outlet Mod, Rear Seat Mod, NGK iridium plugs MySpace
Many thanks for your help.
Stef
2000 = First year truck came out but production began in mid 99. 2000 Tundra's Has had serious issues such as brakes(big time problem's with calpers make sure you find a used tundra with this tsb performed), o2 sensors(haven't had problems with mine) plastic part's that are poor quality mainly fog light's replaced and side markers that leaked really beyond all that not any serious issues to report.Also if you find one with over 90k on miles make sure your timing belt's have been replaced..
2001= Airbags changes,tailgate rail's has plastic part's added and a colored keyed rear handle on limited models (only)
2002=Slight revision done on rear seat more padding added on rear a little bit more incline
2003=Front end grill updates and a cheap plastic bumper
2004= No updates to report
2005=serious power train updates such as new vvti v8 and 5 speed tran's and revision done to headlights, tailights ,navigation system from camry etc etc...
