Loose Rear Hub??
+ Reply to Thread
Results 1 to 5 of 5
Thread: Loose Rear Hub??
  1. #1
    Veteran Member Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue is a glorious beacon of light. Portugue's Avatar
    Join Date
    Sep 2002
    Location
    Hopkinton, MA
    Age
    34
    Posts
    1,033
    Liked
    1 times
    Images
    9
    Rep Power
    212
    Default Loose Rear Hub??
    I just rotated my tires (temps are finally about 40) and I noticed when I put the passenger side rear tire on and tightened, the wheel had a little movement to it. Took it off, and took the rear drum cover off. If I grab the wheel studs, and pull toward me....there is a little play there. Is that normal? Its like the hub can move in and out, its very slight, maybe 1/16" if that.
    Little history, I had to fix that tire over the summer and just used the factory jack to raise that side. Took the tire out and didn't put a floor jack under (not my proudest moment). Went to fill the tire up, came back and of course it had fell off the jack. Everything was fine though and nothing was damaged. It wasn't very high off the ground. I think this is the first time I never used a floor jack....and of course this had to happen.
    I'm wondering if there is a bearing or something there that might need replacement. Any help would be greatly appreciated!
    Joey
    2002 Toyota Tundra TRD Off-Road Package
    Mods: TRD Dual Exhaust, Clear Corners, Aluminum Skid Plate, 2005 Taillights, 2005 Center Console Mod, 10" Subwoofer in Rear Seat Console, blitzsafe iPod interface, Map Light mod, 1" Daystar Lift, Force Stainless Side Steps, Pirelli Scorpion ATR's on 17's, Fog Light Mod Parts 1 & 2C...hopefully more to come
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    SAS'ed #5 dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    34
    Posts
    6,242
    Liked
    159 times
    Images
    119
    Rep Power
    13068
    Default Re: Loose Rear Hub??
    Could be the bearing needs replacement. Not sure how much "play" it should have but, from the sounds of it, it seems too much. To save the cost of labor, remove the axle shaft, drum assembly yourself and take it to a place and have new bearing(s) installed. All you need to do is jack up the rear end and place the side you are removing a bit higher than the other side. This is so the diff fluid doesn't leak out. Disconnect the brake cable and brake fluid line. Remove the 4 flange bolts and slide it out. While you are at, might as well replace the o-ring and axle seal.
  4. #3
    Join Date
    Sep 2002
    Location
    Hopkinton, MA
    Age
    34
    Posts
    1,033
    Liked
    1 times
    Images
    9
    Rep Power
    212
    Thread Starter
    Quote Originally Posted by dyogim View Post
    Well now Im wondeirng if its normal. I just jacked up both sides and they both have the same amount of wiggle. Its really not much, but I can hear it. With the tires down and me rockin it, I don't hear it.
  5. #4
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    34
    Posts
    6,242
    Liked
    159 times
    Images
    119
    Rep Power
    13068
    The only thing I could find in the manual is to:
    Check bearing backlash and axle shaft deviation
    1. Using a dial indicator, check the backlash in the bearing shaft direction. Maximum 0.7 mm (0.028 in)
    2. If the backlash exceeds, replace the bearing
    If what you are noticing is the "play" (backlash) and is more than what's listed above, it's more than likely the bearings. If you have the manual for 00-03 tundras, it's section SA-84.
  6. #5
    Join Date
    Sep 2002
    Location
    Hopkinton, MA
    Age
    34
    Posts
    1,033
    Liked
    1 times
    Images
    9
    Rep Power
    212
    Thread Starter
    Didn't even think to look in the manual. Thanks a ton!! I think I'll have the dealer take a look at it. I don't think its much, just wasn't sure it everything was suppose to be tight. But its seems like a little play "backlash" is normal.
    Thanks for the quick responses!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
