  #16 (permalink)
Old 01-22-2008, 03:47 AM
Sigr6's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2002 Toyota Tundra LE 4x4 TRD
Last Online: Today 01:26 AM
Sigr6 is on a distinguished road.
Sigr6's Photo Albums
Default Re: Timing belt replacement - What else should I get done at the same time?
So can somebody tell me why you would design an interference engine now instead of a non-interference engine?
  #17 (permalink)
Old 01-22-2008, 04:02 PM
Dealer : Toyota of Glen Burnie
2002 Toyota Tundra,
- Other - Wife's Nissan Xterra
Last Online: 11-15-2009 08:46 AM
KFlash is on a distinguished road.
KFlash's Photo Albums
Lesson learned, be nicer to your 180k motor
2002 Tundra AC 4x4 Off Road Package - Revtek coil lift with Wheeler's 1.5" AAL. Superlift Truspeed Recalibration unit. Flomaster dual exhaust. Husky floor liners. Hellwig anti sway bar. Xmas Gift 2006 - 3" Perf. Accessories body lift and Gap guards - Installed 1/6/07! New tires in March 2007 - BFG AT 30570r16 on MT Classic IIs. Total Chaos steering bushing kit. Front swaybar bushing kit from Wheelers Offroad. Stubbie 21" antenna. Underdrive pulley installed with NAPA belt. Timing chain replacement and brake job are next!
  #18 (permalink)
Old 01-23-2008, 02:48 PM
Dealer : Nye Frontier Toyota/Scion
Last Online: 03-08-2008 08:17 PM
ctbale is on a distinguished road.
ctbale's Photo Albums
Originally Posted by kathyricks View Post
The Tundra motor is an interference motor. There was one Tundra V8 owner on this forum who changed the belt at 90K, but didn't change the tensioner. Then at 174K miles, just before he was getting to change the timing belt again (at 180K) the tensioner seized during a full throttle passing manuver causing the belt to come off. Instantly his engine was destroyed when the pistons collided with the engine valves at full throttle. Lesson learned: Replace the tensioner at every timing belt change or live dangerously. Or change the timing belt sooner than 90K the second time it is changed and change the tensioner at that time.
ok, ok, replace the tensioner. My point is if you do a carefull inspection IAW the book, you will make 180k, then replace it.
  #19 (permalink)
Old 01-23-2008, 06:00 PM
Matador98's Avatar
Dealer : Toyota of Santa Maria
- Other - 1987 Land Cruiser,
1999 Toyota Land Cruiser UZJ100,
Last Online: Yesterday 06:43 PM
Images: 20
Matador98 is on a distinguished road.
Send a message via AIM to Matador98 Matador98's Photo Albums
Whatever you say, but that is your risk to take. I'd rather spend the $50 bucks or so for the tensioner. The one on my wife's LC was pretty sticky at 180K.....I wasn't too pleased.
2006 Tundra DC, 80K, K&N Drop-in, Spintech Truck/RV Muffler, BedRug, Bilstein 5100s, VSE Sub
Previously 2000 Tundra, 94K, K&N Drop-in, Spintech Truck/RV Muffler, Hellwig, Bilstein 5100s, 2005 Sequoia Center Console Installed and looking awesome! - TOTALLED
1999 UZJ100 Land Cruiser, 225K, new carpet, no major Mods planned; it's the wifeys
1987 FJ60 Land Cruiser, 209K, K&N Drop-in, Jacobs Ignition, Jacobs Wires, Dynomax Muffler and Hi-Flow Cat, Electric Fuel Pump Conversion, Rebuilt Carb, Rebuilt Combination Manifold, SS EGR Tube, Someday...A Lift
Proud Member of the CBTMA
  #20 (permalink)
Old 01-23-2008, 08:45 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 09:29 AM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
06's had TSB for tensioner replacement due to noise and they were new , i would change it at every TB cycle along with oil seals x 2, water pump, thermostat, and coolant. the idler bearing #1 & #2 should have no issue going to the second TB cycle and they can get loud just before that time comes and no question change them both then! a few change them every time but the will make it to the second cycyle! Some people just do the kit every time and they are smart but have less money than you!
The world's most trusted name in belts, hoses & hydraulics | Gates Corporation surf around here could help with any other questions and thank DJ for the link!!
  #21 (permalink)
Old 01-23-2008, 09:02 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
For better power and fuel economy.
Imagine if Toyota offered two versions of the 4.7 V8, a non interference one with 225 HP and an interference one with 275 HP. Guess which one 95% of buyers would buy?
  #22 (permalink)
Old 01-24-2008, 11:30 AM
ok, shoot ... now you guys got me worried! maybe I should have replaced more stuff when I was in there? I just did TB, pump, t-stadt, and fresh coolant. belt was crackin, pump was squeekin. I inspected the tensioner, and idler bearings. They were perfect. I got the truck at 119k, did it at 119.5K Maybe I will just go 60k, and get it back in 90k intervals, then replace everything. I hope it makes it. Just did headers, and stearing rack bushings, steering shaft seal is next! Should have done it when I was under there givin the rack some lovin ...
  #23 (permalink)
Old 01-24-2008, 12:59 PM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
Last Online: Yesterday 04:35 PM
ddvk is on a distinguished road.
ddvk's Photo Albums
Can someone educate me on why there are belts in many Toyota engines?
Shouldn't they have migrated to chains since chains have been on MB/BMW/Nissan's for decades?
  #24 (permalink)
Old 01-24-2008, 02:09 PM
kathyricks's Avatar
1993 Toyota Truck
Chains have chain tensioner problems too over time. Just like belts do. And replacing a chain mechanism is significantly more costly and labor intensive than changing a belt. Chains also stretch over time, retarding valve timing. Timing belts don't stretch. So there are pros and cons to chains vs. belts.
Unlike belt tensioners which come with sealed bearings, chain tensioners are lubricated by engine oil. So chain tensioner life is greatly influenced by oil change frequency. The owners who follow the tried and true 3-6 month / 3,000-5,000 mile rule with either dino or synthetic oil are the ones who typically get 400,000 miles or more of life out of their chain tensioner.
  #25 (permalink)
Old 01-24-2008, 04:10 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Last Online: 11-17-2009 05:50 PM
Images: 8
Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke Sanosuke's Photo Albums
Timing belts don't stretch? Thats not true. They do stretch over time.
Sanosuke!
  #26 (permalink)
Old 01-24-2008, 06:36 PM
kathyricks's Avatar
1993 Toyota Truck
Originally Posted by Sanosuke View Post
Timing belts don't stretch? Thats not true. They do stretch over time. Sanosuke!
Technically you are correct, but timing belts don't stretch enough to retard valve timing. A stretched timing chain, on the other hand, can retard valve timing by up to 12-16 degrees.
  #27 (permalink)
Old 01-24-2008, 08:34 PM
2002 Toyota Tundra,
Hey folks.. I thought I saw a post that mentioned the timing belt kit offerred on ebay for $220, but couldn't find it again. It includes water pump, belt, seals tentioner and idler bearings, and serp belt.
Anyone have any thoughts on this kit. I don't know whether it comes with WP gasket and those two o-rings.
  #28 (permalink)
Old 01-25-2008, 01:11 PM
KLINDSEY's Avatar
Dealer : Beechmont Toyota
Last Online: 11-18-2009 08:22 PM
KLINDSEY will become famous soon enough.
KLINDSEY's Photo Albums
Originally Posted by KFlash View Post
Sounds like there are a few of us out there ready to tackle this job. Between the TSM tutorial and the one based on the Lexus, this really doesn't seem bad at all. I have a few days in early Feb where I am going to give it a shot. Should be around 92K by then. Hope it isn't freezing!
Where did find the TMS tutorial I'm @ 88500 now looking to do this in March time frame.
Kevin
KLindsey
  #29 (permalink)
Old 01-25-2008, 01:16 PM
this is the item number on ebay. 310017516915 seems like a good price for good parts. although, not sure if the Koyo idler bearing, SKF tensioner bearings are as important as the tensioner? if you want to to everything, get the tensioner from dealer, and thermostat, coolant, and o rings. then you will be good for another 100K!!
  #30 (permalink)
Old 01-25-2008, 02:49 PM
kathyricks's Avatar
1993 Toyota Truck
Koyo is an OEM supplier to Toyota, but SKF is a Mexican brand. I've noticed the metal finish on the roller of the tensioner of aftermarket brands of bearings is not a smooth and finely polished as on the OEM brands like Koyo and NSK. Rougher surface could = more belt wear. If the tensioner bearings of aftermarket tensioners are not as high quality either, tensioner life may be shorter.
