This is a discussion thread titled "ATF checking dilemma", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-21-2008, 01:53 AM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
Last Online: Today 12:18 AM
wirelessf is on a distinguished road.
wirelessf's Photo Albums
Default ATF checking dilemma
I have recently changed my ATF fluid and now have to check the level. I usually check the level after freeway driving where the fluid gets hot. I've read the how to on the top of this forum and searched around but I wanna see if there's a specific way to check atf level on the 2001 tundra.
1. When checking the fluid, it says to get it up to operating temp. On my scanguage, the water temp reads 86 degrees C. Is this the optimal temp to check ATF level?
2. Should I idle to operating temps to check ATF fluid and run the gear selector to each gear or drive it around for 20 min on the freeway, get the trans all warmed up with the fluid running through all the gears (R-1-2-3-OD)?
3. Would the raked stance of the tundra affect the dipstick reading level?
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Old 01-21-2008, 03:35 AM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: Today 02:34 AM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Default Re: ATF checking dilemma
Personally, I don't think it needs to be that complicated. I'd just drive around for a while (20-30 min if you like); go through all the gears in the meantime; park somewhere level; let it sit long enough so most oil that will drip will drip back into the pan. Then check.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
Old 01-21-2008, 09:17 AM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
Last Online: Yesterday 01:28 PM
ddvk is on a distinguished road.
ddvk's Photo Albums
Driving 1Q higher/lower is not going to destroy your tranny. So relax, I have driven thousands of miles with less ATF and many thousands of miles with more ATF.
If your notice erration with bubbles in the ATF then you have really crossed the upside limit. Drain a little and see that erration of fluid does not happen.
Driving with less is not detrimental too.
Old 01-21-2008, 12:23 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: Yesterday 04:11 PM
kathyricks's Photo Albums
wirelessf, you're very smart to be concerned about establishing a precisely correct fluid level for multiple reasons: 1) a level slightly low (1 pint or more) = reduced power and fuel economy and higher tranny operating temperatures and wear 2) a level slightly high (1 pint or more = possible aeration and foaming of the fluid at high summer temperatures = reduced parts lubrication and faster parts wear. Ford owners manuals devote two pages telling owners how important it is to establish a level that's not more than one pint too high or too low.
Toyota automatics run cooler than American automatics so it can be hard to get them up to operating temperature. I suggest 20-30 minutes of city and suburban driving rather than freeway driving. Then park on a level parking lot and shift slowly through all the gear ranges ending in ParK. Then take your dipstick reading. Try to get the dipstick reading on the Full mark or a tad (1/8 inch) below the Full mark
Old 01-21-2008, 11:33 PM
LifeTech's Avatar
Slummin'
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 01-06-2009 03:25 PM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Only Toyota engineers know that improper techniques regarding checking Fluids will prevent their Toyota vehicles from going 500K.
P Bot
Bookmarks
