  #46 (permalink)
Old 01-26-2008, 11:15 AM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Default Re: WOW! Fram vs Toyota oil filters
Originally Posted by Burger Steak & Eggs View Post
You are right Kathy but the wrenches often slip on the filter.
Exactly...those cap wrenches will ultimately slip. Many times for me.(on OE filters.)
I use a tension spring "one way clamp wrench and a 3/8 ratchet.(The best for removing) But they only work in counter clockwise direction. Yu cant wrench tighten an additional 1/4 turn with this type of wrench.
The 1" welded nut is a nice feature.
LT
  #47 (permalink)
Old 01-26-2008, 11:25 AM
LifeTech's Avatar
Originally Posted by Sigr6 View Post
You can get them for about $11 a filter I believe.
That's not too hazardous after all.
  #48 (permalink)
Old 01-26-2008, 11:31 AM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
Last Online: 11-20-2009 04:35 PM
ddvk is on a distinguished road.
ddvk's Photo Albums
If you torque the damn filter correctly you don't need any of these gizmos. FYI, in my yrs of driving autos, I have never had to use a wrench or any other gizmo to get the filter out.
Thumb rule: Turn the filter till it cannot turn without force. Then turn the filter full turn, next day after the seal is heated to make contact with the oil pan, get under and turn counter clockwise 1/4 turn. The seal between the filter/pan is broken but broken enough not to leak.
  #49 (permalink)
Old 01-27-2008, 05:11 PM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: 11-18-2009 11:10 PM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Overkill I think. Just handtighten, see how much effort to loosen, and then tighten again if it loosens too easily. Then, tightne again until you feel a good moderate tightness.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
  #50 (permalink)
Old 01-27-2008, 05:35 PM
LifeTech's Avatar
Did anyone consider that there is an actual torque spec for the Oil filters.
Makes me wonder how hand tightening would suffice. Although many people just hand tighten. And depending on your position to the Oil filter and where located, your leverage for hand tightening may be limited.
An I confess that I have done this a few times over the years.
But, 99.9% of the time, I always hand tighten then wrench one 1/4 turn additional.
A loose filter will KILL an engine for sure. And it always gets yu when your pants are down.
And the engine is toast. Sometimes your lucky and it will loosen just enough to trickle leak or sweat at the seal. (best case scenario)
I have seen this before on customers vehicles.
Why take a chance for the sake of convenience.
Wrench an additional 1/4 turn. Or just torque to spec.
LT
  #51 (permalink)
Old 01-27-2008, 05:42 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 01:05 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
I would not feel comfortable with hand tightening alone. Throw in the slippery filter and awkward working angles under the truck, and I have less confidence the filter could be made tight enough such that it would not work itself loose.
  #52 (permalink)
Old 01-28-2008, 01:41 AM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
I've always hand tightened and never has any leaks or loosening problems. Probably because I use OEM filters. But I've always needed a cap wrench to loosen the filter. A good fitting toyota specific metal cap wrench will not slip.
  #53 (permalink)
Old 01-28-2008, 01:51 AM
Sigr6's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2002 Toyota Tundra LE 4x4 TRD
Last Online: 11-21-2009 01:26 AM
Sigr6 is on a distinguished road.
Sigr6's Photo Albums
Hand tightening is all that is needed.
  #54 (permalink)
Old 01-28-2008, 08:15 AM
2XOverhead's Avatar
Moderator
Originally Posted by kathyricks View Post
Probably because I use OEM filters. .
Oh man, don't you ever stop? I've used M1 and Puro1 w/ no probs either.
Cap wrenches are good though. Only thing is it's sometimes a PITA to pry it off the filter after you've taken the filter out.
Coming Soon?
  #55 (permalink)
Old 01-28-2008, 11:05 AM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 10-05-2009 12:31 AM
mral1515 is on a distinguished road.
mral1515's Photo Albums
x2
All we ever do is hand tight.
Master Toyota Tech
ASE Master Tech
Shop Foreman
16 years with Toyota
  #56 (permalink)
Old 01-28-2008, 01:09 PM
benbeaux's Avatar
Dealer : Toyota of Richardson
2006 Toyota Avalon Desert Sand Mica,
2006 Toyota Tundra Desert Sand Mica DC,
- Other - 2007 Suzuki Burgman
Last Online: 11-03-2009 07:50 PM
Images: 2
benbeaux is on a distinguished road.
benbeaux's Photo Albums
Oil the o-ring & 3/4 turn hand tight. Never a leak since 1982.
  #57 (permalink)
Old 01-28-2008, 07:35 PM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
Last Online: Yesterday 10:12 PM
Images: 9
longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light.
longwoodklon's Photo Albums
Don't the instructions say:
1) Oil oring
2) Thread on new filter until o-ring makes slightest contact with engine
3) Then tighten 1 full turn
I tighten my Purolator 359 degrees after oring to engine contact is made, mainly because the cheap metal begins to deform at precisely 359.5 degrees. Use the OEM filter, you can get that extra 1 degree of 'tightness'.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
  #58 (permalink)
Old 01-28-2008, 08:50 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
I never oil the "O" ring, and I hand tighten and wrench a 1/4 turn, By using Toyota OEM filters I'm insured to receive the highest quality product, including a pre lubed O ring, part of the attention to detail from Toyota that goes a long way to achieve 500k trouble free miles...
  #59 (permalink)
Old 01-28-2008, 09:40 PM
kathyricks's Avatar
1993 Toyota Truck
The $3.95 Toyota (Denso) oil filter made in Thailand DOES come with a prelubed O-ring. The instructions on the box say to apply engine oil to the o-ring anyway and tighten it 3/4 turn using a cap type oil filter wrench.
The '01-'02 Tundra transmission has a mechanical weakness (its exploding planetary gear) so no amount of Bobistheoilguy tranny products (magnafine tranny filters, auto-rx, Amsoil Universal tranny fluid or Mobil 1 ATF will save it from exploding before 500K. Instead of spending money on those gimmick products, you'd be better off buying a spare used '03-'06 tranny from an auto wrecking recycling company like www.taprecycling.com
  #60 (permalink)
Old 01-28-2008, 11:01 PM
MOREPOWER's Avatar
The '01-'02 Tundra transmission has a mechanical weakness (its exploding planetary gear) so no amount of Bobistheoilguy tranny products (magnafine tranny filters, auto-rx, Amsoil Universal tranny fluid or Mobil 1 ATF will save it from exploding before 500K. Instead of spending money on those gimmick products, you'd be better off buying a spare used '03-'06 tranny from an auto wrecking recycling company like TAP Recycling (800) 765-7100
What!! why thats! Thats just Blasphemy!
Everyone here knows Toyota's run forever, and in the unlikely event that they require a tear down, the internals will look just like they came out of a machine shop hot tank... Providing you use only Toyota fluids and filters...
