This is a discussion thread titled "Ticking noise in engine only under certain conditions", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-19-2003, 08:32 PM
Last Online: 09-05-2005 09:58 PM
randy cain is on a distinguished road.
randy cain's Photo Albums
Default Ticking noise in engine only under certain conditions
I have 132,000 miles on my 2001 Limited and it has started making a "ticking" noise somewhere around the left manifold area in the engine. It does not do it on cold start up and not consistently. Most of the time I hear it is after I driven the truck and let it sit for 15-30 minutes. It usually goes away in less than a minute. It sounds like an exhaust leak but one would think that it would make the sound more consistently and especially on cold start-ups. Talked to one Toyota dealer and was told that they have had to do some exhaust manifold replacements due to cracking. He also said that 2000 and early 2001 had some problems with "piston shirtail slapping" and that Toyota did not think it was a problem but corrected in later models. Anyone have any ideas what might be happening?
Moderators Note: Thread moved to the Engine & Drivetrain Forum for better exposure and replies. PM was sent to thread starter of its relocation. --- Possum
Old 02-19-2003, 09:20 PM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
Have you checked the valve clearances and changed the timing belt yet? I would start here. Doubt if the manifold "developed" the crack after 100K - the manifolds usually come "cracked" from the factory from an over zealous air wrench.
Old 02-20-2003, 02:09 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
I doubt it. A more likely cause is p$ss poor welding and/or design.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 02-20-2003, 09:02 AM
Did timing belt just past the 100,000 mark...keep truck well maintained due to the high mileage I drive it...but have not had valve clearences checked unless they were at timing belt install.
Old 02-24-2003, 01:54 PM
Last Online: 03-01-2003 02:54 PM
rckstr is on a distinguished road.
rckstr's Photo Albums
my 2001 only has 33000 miles and make that ticking noise when i start it in the morning.
Old 02-26-2003, 01:14 PM
Last Online: 03-12-2003 01:13 PM
BNR32 is on a distinguished road.
BNR32's Photo Albums
RandyCain,
I've also got a 2001 Tundra, mine is a Ltd 4X4 w/ 50k on the odometer but I have the same symptoms on my truck. Every so often I'll here a ticking sound that seems to come from the driver's side ex. manifold. The other day when I was changing my oil I had the hood open and tugged the throttle open a bit and it didn't sound like an exhaust leak at that point.
I uncertain if the noise has anything to do with valve clearances, if my valves are that far out of adjustment I'm going to be looking for some even more serious problems in the head.
Does anyone know if the manifolds are cast iron or if they are welded tublular peices? I didn't even think to look when I was uunder the hood.
Sean
Old 02-26-2003, 01:49 PM
Jimbo88's Avatar
Jimbo88
Dealer : Toyota Of Scranton
Last Online: 12-04-2006 09:56 PM
Jimbo88 is on a distinguished road.
Jimbo88's Photo Albums
I have 89K on my 2000, and i have been noticing some ticking while driving. I have no idea where it is coming from, other than "under the hood somewhere"..
It's common when cold, and internittently under load, hot or cold.
I also see a big puff of smoke in the rear view when I hammer down on the pedal, but again, it doesn't happen every time...
I hate intermittent problems; it is really difficult to narrow down the exact conditions under which problems actually manifest, let alone determine the true cause(s) of the problem...
Anyone have any sceintific(or qusi-scientific) tests I could perform to get a better idea what is going on here?
I plan to have my dealer do a compression test at next service..should I be due for a new timing belt yet?
Old 02-26-2003, 02:12 PM
Dude Boy's Avatar
2000 Toyota Tundra,
With the truck cold, have someone start it up and put it in gear while holding the brake. Have them apply a bit of throttle while you listen at each side of the engine. I used a piece of small diameter hose and put it through the wheel well right up into the manifold area. Hold the other end of the hose to your ear. It's common for the noise to almost go away when the engine is warm. The manifolds are welded up out of stainless tubing. See picture below.
Old 04-24-2007, 11:21 PM
Dealer : Antwerpens Toyota Village
2001 Toyota Sequoia
Last Online: 06-18-2007 06:48 AM
seqoia2001 is on a distinguished road.
seqoia2001's Photo Albums
Default Re: Ticking noise in engine only under certain conditions
[quote=Dude Boy;105812]With the truck cold, have someone start it up and put it in gear while holding the brake. Have them apply a bit of throttle while you listen at each side of the engine. I used a piece of small diameter hose and put it through the wheel well right up into the manifold area. Hold the other end of the hose to your
Old 04-26-2007, 01:59 PM
minomatchu's Avatar
Dealer : Eddy's Toyota of Wichita
Last Online: 01-05-2009 03:27 PM
minomatchu is on a distinguished road.
minomatchu's Photo Albums
My 2000 Tundra 4.7L w/ 59K does the exact same thing. It has been doing it for as long as I can remember. People tell me it sounds like an exhaust leak when they hear the truck. The ticking noise is especially noticeable when cold. I'd like to hear from someone that had the problem and solved it.
Love my Tundra
Old 05-10-2007, 01:21 PM
Dealer : Toyota City
2001 Toyota Sequoia,
1998 Toyota Avalon
Last Online: 06-25-2008 02:11 PM
mnarcticcat is on a distinguished road.
mnarcticcat's Photo Albums
2001 Sequoia... 134,000 miles... I to have the ticking noise. The harder I step on the gas the ticking noise increases!
Current:
2001 Toyota Sequoia SR5 4WD
1998 Toyota Avalon
Past:
1998 Toyota Tacoma SR5 Xtra Cab 4WD
1997 Toyota 4Runner SR5 Limited 4WD
1996 Toyota Tacoma Reg Cab 4WD
1984 Toyota Pickup 4-Speed 2WD
Bookmarks
