This is a discussion thread titled "Oil drain plug on Tacoma Regular Cab Prerunner", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-06-2008, 04:31 PM
Dealer : Mossy Toyota Scion
- Other -
Last Online: 10-19-2008 09:40 PM
Debellocivili is on a distinguished road.
Debellocivili's Photo Albums
Default Oil drain plug on Tacoma Regular Cab Prerunner
I understand that the drain plug for the engine oil is similar to the plug for the transmission fluid and that some people have confused the two.
I will be changing my oil on my 4-cylinder 2.7L Engine (2TR-FE) regular cab prerunner and I want to make sure I unscrew the oil drain plug, and not the plug for the transmission fluid. After looking under my truck I have doubts.
If I took some pictures, anybody feel qualified to say yeah or nay to the drain plug? Does anybody have any schematics for the reg prerunner? Own one and changed the oil?
Cheers!
Old 02-06-2008, 11:57 PM
LifeTech's Avatar
Slummin'
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 01-06-2009 03:25 PM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Default Re: Oil drain plug on Tacoma Regular Cab Prerunner
Cheers!
It all comes down to this.
If yu can differentiate between what the trans. looks like compared to the Engine... then yu really can't make a mistake.
But ,do send us pix, to point it out.
Get under there and look at every thing for 10 minutes. It should be apparent. Especially if yu have some reference pix from any manuals.
The engines oil pan sits directly under the engine block 99% of the time.
Hope this helps to give yu more confidence. Yu really have to lay under there for several minutes and it should be easy to figure out. It should just make sense.
A Mistake will happen if yu just reach under and NOT study which drain plug is which.
Lay under there and study all the components and wher the trans. is attached to the engine.
I can't explain it any better.
LT
Old 02-07-2008, 01:12 AM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Yesterday 11:31 PM
Only Toyota for me is on a distinguished road.
All the toyota's i've had, both the bolts use a 14mm socket to loosen.
However, Just like lifetech said, the oil drain pan is directly under the engine. The transmission drain plug is further back.
Also, the trans plug is a smaller bolt than the oil plug and screws in vertically. The oil plug usually is on an angle pointing towards the rear of the vehicle. This i'm sure is for folks that pull the vehicle up on ramps to change the oil.
I haven't had any vehicles with the 2.7, so i'm not 100% sure, but i'm pretty confident yours will be the same way.
Old 02-08-2008, 03:38 PM
- Other -
I tested it and a 14mm socket will loosen the plug in question; however I've read that 14mm is also the size for the transmission fluid plug.
I took pictures. I think it is pretty clear which plug I'm looking at: it is the grey plug on the bottom of the black pan. I can label it if necessary.
oil-drain-plug-tacoma-regular-cab-from-passenger-close.jpg   oil-drain-plug-tacoma-regular-cab-from-passenger-far.jpg   oil-drain-plug-tacoma-regular-cab-from-driver-far.jpg
Old 02-08-2008, 10:48 PM
Big_Al1's Avatar
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: 01-07-2009 01:35 PM
Big_Al1 is on a distinguished road.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
That is the oil drain plug on the black pan.
Old 02-09-2008, 05:46 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: Yesterday 04:11 PM
kathyricks's Photo Albums
The 24mm bolts on the aluminum transmission housing are the drain and fill plugs for the 5 manual transmission.
Old 02-10-2008, 09:41 PM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 01-05-2009 09:50 PM
mral1515 is on a distinguished road.
mral1515's Photo Albums
Most people are having problems determining whether they are draining the Automatic Transmission's plug or the oil drain plug. First you have a manual tranny so this is no brainer. Second I hope you don't take any offense to this if you can't tell which plug is for the oil and which is for the transmission you need to pay someone to change your oil.
Master Toyota Tech
ASE Master Tech
Shop Foreman
16 years with Toyota
Old 02-11-2008, 10:27 PM
LifeTech's Avatar
Slummin'
Get a manual for starters...doesn't have to be a Toyota manual.
What yu want to do is fundamental auto maintenance. Nothing personal, however, practical knowlege is generallly hard to get from others on line.
If not, sure pay someone once to do it and learn from them.
LT
Old 02-11-2008, 10:34 PM
mral1515's Avatar
2007 Toyota Tundra,
LT
Yu ever think of running for office? Yu need to change your name to Mr nice guy.
Master Toyota Tech
ASE Master Tech
Shop Foreman
Old 02-16-2008, 09:21 PM
LifeTech's Avatar
Slummin'
In my line of work I have to be a diplomat.
BTW, I can't run for office until I separate from my current post for 2 years.
" yu can bring a horse to water, but yu can't make him drink it"
LT
Old 10-19-2008, 08:54 PM
Dealer : Glen Motors
2008 Toyota Tacoma double cab long bed
Last Online: 10-21-2008 05:24 PM
FirstToyNJ is on a distinguished road.
FirstToyNJ's Photo Albums
Ok, I'm about to change my oil and take out the break in oil and put in mobil 1 5-30. I'd rather be safe than sorry and double check which drain plug is the oil pan. Looking under my 08 Tacoma, is the drain plug the one that is closest to to the front of my truck?
Old 10-19-2008, 09:39 PM
- Other -
There are plenty of members who have more knowledge than I do and they may be able to answer your question as to whether the drain plug the one that is closest to the front of your truck.
However, if you look at the pictures I took, you will clearly see the drain plug and oil pan on a 2007 prerunner regular cab. You should also get a pretty good idea as to the location. In the case of my truck, the plug and pan were in a very conspicuous location.
Old 10-21-2008, 11:51 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 06:26 PM
HOGWILD will become famous soon enough. HOGWILD will become famous soon enough.
HOGWILD's Photo Albums
Master Portal - forums.bauchan.org - Toyota Workshop & Repair Manuals - page: 3 page 3 has some Taco Manuals in PDF hope ya find one that works and i hope you have high speed!
Bookmarks
