This is a discussion thread titled "Long term fuel trim too high at idle", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-15-2008, 01:43 AM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
Last Online: Today 12:18 AM
wirelessf is on a distinguished road.
wirelessf's Photo Albums
Default Long term fuel trim too high at idle
For those who have a scanguage, there is a xgauge code that allows you to read the fuel trims. Pretty neat feature I should say, but then discovered a potential problem.
Is it normal for the long term fuel trim to be high at idle? The scanguage reads 22% at idle, but goes to single digits when I drive it. Is there a potential vacuum leak? Or is it normal for it to lean out at idle?
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Old 02-15-2008, 09:53 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 06:26 PM
HOGWILD will become famous soon enough. HOGWILD will become famous soon enough.
HOGWILD's Photo Albums
Default Re: Long term fuel trim too high at idle
Cold Engine RPM Idle? If so i think the ECM has control of this until engine warms to normal operating temp. If you are allready at normal engine temp and normal RPM's i think it would be an issue if reading was that high after a few seconds at idle RPM's!
Old 02-15-2008, 11:14 AM
wirelessf's Avatar
2001 Toyota Tundra,
yeah it was already at operating temp.
Old 02-16-2008, 10:03 AM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra V8 AC,
- Other -
Last Online: Yesterday 07:02 PM
Tones is on a distinguished road.
Tones's Photo Albums
Don't know much about these parameters, but I read just the other day that when a MAF starts to go or gets dirty, it can cause a rich condition at idle and lean condition at higher rpms. One symptom is a slight loss of power. It may or may not set a code.
Old 02-16-2008, 05:05 PM
wirelessf's Avatar
2001 Toyota Tundra,
I looked around for some answers and the reason for this is that it could be an air leak.
How do I test for air leaks?
Old 02-17-2008, 06:23 PM
wirelessf's Avatar
2001 Toyota Tundra,
Well I checked the PCV valve, changed the grommet and changed the tubing going to the TB. Now it reads 13-17% LTFT (long term fuel trim) I zip-tied all vacuum hoses going to the intake manifold and replaced all stiff/cracked hoses.
Is it possible that an exhaust manifold leak could be the problem?
Bookmarks
