To my knowledge.. there aren't simple plug in chips for the Tundra. You can send your ECU into Jet, and they'll work on it though. But, I've heard thats not worth it. Check the thread just below this one about the ECU piggyback. Member nitrousfed sells a lot of custom Tundra stuff (new heads, pulleys, turbos...) including a chip of sorts.
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
