Re: engine makes funny noises
Need more info. Does it continue to make the noise after it warms up? One easy test for belts is, while the engine is running and making the noise, drop a few drops of water on the belt. If it quiets the noise, then you found it. Just did this the other day to the wife's Corolla.
If it always makes the noise, and it's not a belt, I'd first look for something on or around the fan. I had a Camaro that sucked up a plastic bag...
Good luck!
Just thought of one other thing. A torn belt can make a flapping noise.
