Re: vibration
[QUOTE]Originally posted by jeffrey smith
[B]Has anybody found a cure for the vibration between 25-40 mph
in a tundra 2002 4 wheel drive? worse in cold weather!
VIBRATION IS UNDER THE FLOOR BOARD ON THE DRIVER SIDE!
Jeff:
.....And so is the front propeller shaft. You might try greasing the U-joints. When I did, I found some very stiff grease in those joints. I purged the seals using Amsoil No. 2 lithium complex synthetic grease and put Mobil 1 75W90 synthetic in the front differential and transfer case.
My 02 4x4 doesn't vibrate even at -10F.
Before engaging 4WD to stop a vibration, it would be wise to consider that this system is a relatively light duty, part-time 4WD that is intended for use on low traction surfaces such as ice, snow, mud, wet grass, and perhaps loose gravel. The hallmark of a good tire is good wet and dry traction. Operation in 4WD under high traction conditions can do more harm than good and may result in vibration all the time.
Herb
