Originally posted by Agent WD-40
Thanks for the reply. I'm programing (with another guy) a 1.9L Saturn engine in a gas/electric hybrid for Explorer using a MoTec. It doesn't run too bad on the stock maps. Do you have any tips you can give me? Do you know a place where I can gather theroy on engine management with a computer? Like a good book or a website or something. In what way do you tune with the O2 sensor? How would that relate to the Lambda sensor reading?
So far we have played a little with it on the chassis dyno. Yeah, the MoTec is pricey. Were going to leave it in a place where we can disconnect it and take it with us. Thanks.
Do a search for Raymond T. Bohacz. The man is a DFI and engine theory/tuning guru.
As for hints,start rich. Rich fouls plugs,lean blows motors
Don't be very agressive with timing. And don't rely entirely on the O2 sensor for tuning,check the spark plug condition too (taking it back old school hehe)
O2 and Lambda sensors are the same thing,you say "po-tay-toe" I say "po tah toe". Only difference is how values are read. One lambda is equal to an air/fuel ratio of 14.7:1 (stoichiometric). I prefer going by A/F values,it's a little hard to visualize ".9 lambda" compared to say 12:1 A/F ratio.
I usually tune for WOT power since in most situations the base maps work good driveability-wise. We try try to run at least 12:1 A/F,nothing leaner. Idle and part throttle you're looking for that stoich ratio,this is the value where a cat. converter works most efficiently. This is with a wideband O2 sensor,not the usual 1-wire or 4-wire heated sensor,those don't read accurately enough in the richer or leaner AF valuees,it's primarily designed to read stoich ratios. The wideband sensors themselves cost over $100 and you need a special driver circuit to interface them to most standalone systems.
