Old 03-13-2008, 01:08 AM
Sigr6's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2002 Toyota Tundra LE 4x4 TRD
Last Online: 02-08-2010 03:07 PM
Sigr6 may have some regrets.
Sigr6's Photo Albums
Default mobil1 grease ok for all zerks in drivetrain?
Mobil 1 Synthetic Grease
is this ok for all 8 zerks on an '02 tundra 4 x 4?
Old 03-13-2008, 04:59 AM
2003 Toyota 4Runner
Last Online: Today 12:24 AM
canddmeyer is on a distinguished road. canddmeyer is on a distinguished road. canddmeyer is on a distinguished road.
canddmeyer's Photo Albums
Default Re: mobil1 grease ok for all zerks in drivetrain?
I use Mobil 1 grease on all the zerks on my 2003 4Runner. It's the best available, and problem free.
Old 03-13-2008, 02:43 PM
Hugemoose's Avatar
Dealer : Performance Motors Toyota
Last Online: 03-09-2010 11:31 PM
Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold. Hugemoose is a splendid one to behold.
Send a message via AIM to Hugemoose Hugemoose's Photo Albums
I imagine it would be fine, but what's wrong with normal grease?
I use mobil 1 in my engine, but the driveshaft? I'm not knocking you or anything, just seems a little excessive considering most people never grease their drivetrain and there really aren't any issues.
Plus, three sticks of grease from Advanced Auto is only like 3 bucks.....or free since I have a friend there
David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
Old 03-13-2008, 07:44 PM
Sigr6's Avatar
It's not that expensive, just wanted to make sure it was ok. *shrug*
Old 03-14-2008, 12:02 AM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 11-29-2009 07:51 PM
kathyricks may have some regrets.
kathyricks's Photo Albums
Originally Posted by Sigr6 View Post
Mobil 1 Synthetic Grease is this ok for all 8 zerks on an '02 tundra 4 x 4?
Probably not OK. Look in the rear pages of your owners manual where it talks about what oils, spark plugs and so forth to use.
For the various zerk fittings, generally Toyota specifies either a plain "Lithium base chassis grease" or "molybdenum disulfide lithium base chassis grease"
Mobil 1 cannot be used in any fitting that requires "molybdenum disulfide lithium base chassis grease".
Old 03-14-2008, 12:51 AM
Sigr6's Avatar
I see that some on here have already used it.
There isn't really a way to remove it and replace it with molybdenum disulfide lithium base chassis grease. *shrug*
I guess I'll see if I can find some molybdenum disulfide lithium grease then which i believe can be used on all zerks from some further research i've done.
Old 03-14-2008, 02:10 AM
kathyricks's Avatar
1993 Toyota Truck
Valvoline make a moly fortified lithium base synthetic chassis grease. I've seen it at NAPA and some other auto parts stores.
Old 03-14-2008, 08:01 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: 03-13-2010 09:27 AM
Images: 11
HOGWILD is on a distinguished road. HOGWILD is on a distinguished road. HOGWILD is on a distinguished road.
HOGWILD's Photo Albums
Toyota Corporate told me that it was ok to use Moly Lith in all fittings but not to use straight Lith in all fitting because it would not protect the zerks that called for Moly Lith, keeps from using 2 guns and 2 greases.
Old 03-14-2008, 10:52 AM
Sigr6's Avatar
yeah, my question is let's assume that whomever owned my truck before used a lithium only based grease. There is no easy way to get that out. Do I just use moly gong foward and call it good?
Old 03-14-2008, 12:52 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 11
Toyota said using Lith on a joint that called for moly lith would leave it unprotected per their specs?but that Moly Lith would not hurt joints specd for lith? i would just go with straight Moly Lith on everything and just let it work its way out and quit loosing sleep about it! i do it on both of my 4x4's and my older truck has a few more fitting plus i use it more in the woods. to my knowledge it has never had a failure of any joint and i got truck when it had 140K on it and it has 237K on it now and i keep them lubed at every oil change! same as my 06!
Grainger Industrial Supply: Grease,Automotive 4ZF44 this is what i use!
Old 03-14-2008, 04:17 PM
Sigr6's Avatar
cool, i'll pick up some moly lith and just use that next oil change.
Old 03-14-2008, 07:05 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 02-13-2010 10:48 AM
LifeTech is on a distinguished road. LifeTech is on a distinguished road. LifeTech is on a distinguished road.
LifeTech's Photo Albums
So what is wrong with M1 grease?????
All afraid are yu??? Then be afraid of the big bad wolf!
Old 03-14-2008, 08:06 PM
Sigr6's Avatar
I think they are saying mobil1 is lithium only.......when you should be using
molybdenum disulfide lithium *shrug*
Not really sure it will make a difference but can't hurt to pick up moly instead.
Old 03-15-2008, 02:18 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 11
Mobil Syn lube says nothing about Moly Additive in MSDS.
Old 03-15-2008, 02:58 PM
2003 Toyota 4Runner
Bottom line is this > if you don't grease it, it won't get greased, because I haven't come across a dealer yet who greases the zerks. This is a common complaint, especially on 4Runner's for driveshaft noise.
