This is a discussion thread titled "Attention Toyota auto technicians", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
I would be interested in hearing if this is possible. I think the electronic end might be the more difficult part of this equation. I'm not sure how all the computers are set up though and how compatable all that is. But that is my guess.
Physically the transmission would fit. But if i am not mistaken the computer logic to run the transmissionn from the 2003 is not compatible with the computer from the 2001. You would have to swap out the entire wiring, computer, and some of the other electronic computers.
I think this is so, because the 2002 TRD supercharger and TRD computer is not compatible with the new 2003 tundra. TRD is working on it, and their reason it wont work is beacuse the 2003 computer uses 32 bit logic where the 2000-2002's use only 16 bit.
So basically I would need the entire computer setup alone with the 4-runner transmission and rear axle ratio to make it work. I guess that would be kind of expensive!
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
208 HP @ 4800 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM Bone stock
Dyno run results click here
I belive the v6 tacoma uses the same 4 speed auto tranny as the sequoia and tundra. If so why not use a 5 speed from a v6 taco for the same model year as your tundra?
You are correct very expensive, it all has to do with the 2003 computer logic, it is different starting this year.
Also they do not affer a 5 speed auto in the Tacoma V-6.
23 yrs with TOYOTA
I was playing around with the different transmissions on my drag program and also comparing Motor trend testing on the Tundra and new 4-Runner. It seems the only real benefit/difference is the greater gear reduction in first and second gear. The EPA gas mileage figures are also a little better at 15-18 for a 4*4 model, which is the same for my 2WD Tundra. Passing power on paper from 45 mph and up looks like it would be in favor of the four speed transmission with the 3.91 axle ratio compared to the five speed with the 3.73 gears. Off the line power would be in favor of the five speed though.
It’s probably not worth the effort!
stock exhaust
TRD LSD
220 HP @ 4800 RPM
208 HP @ 4800 RPM
204 HP @ 4800 RPM
Hi,is the 5th gear taller than the current 4th gear?I guess I am really curious if the 5th gear-differential combo is actually "taller" than the 4th-differential combo?What will it turn at 60 mph.The current Tundra does about 1900 RPMS.Thanks,Charlie PS I think the stock wheels-tires on the 4 Runner are the same 265/70x16 as out Tundra
Using my drag program I get 0-60 in 8 seconds and the quarter mile coming in 16 seconds @ 85.3 mph with the four speed.
I get 0-60 in 7.4 seconds and the quarter mile coming in 15.63 seconds @ 86.7 mph with the five speed. This transmission would be better for towing and utilizing the torque of the 4.7-liter engine better!
stock exhaust
TRD LSD
220 HP @ 4800 RPM
208 HP @ 4800 RPM
204 HP @ 4800 RPM
