Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Fire causing Engine to fall Apart?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-20-2008, 02:37 PM
Dealer : Bob Howard Toyota
1995 Toyota Camry
sooners123's Photo Albums
Last Online: 05-13-2008 05:10 PM
sooners123 is on a distinguished road.
Default Fire causing Engine to fall Apart?
Recently, my oil filter came off while driving and a small fire started right above the engine. The car worked fine for a while. But, the fire caused the timing belt to crystallize and the teeth got ripped off. The result was pressing the gas pedal and the car not moving forward.
I replaced the timing belt. The first time I started the car, the engine stumbled a bit. But, after that, it never did it again. The car worked perfectly.
However, recently, the same situation happened (where I press gas pedal and car not moving forward). When I start the car, the engine would stumble sometimes and not function. At certain lucky times, it would start and function normally.
The engine seems to stumble when the car comes up to operating temperature and pressing on the gas pedal. It idles fine.
What could the problem be? I can't imagine it being the timing belt again since it was changed two weeks ago.
Old 03-20-2008, 03:45 PM
Sigr6's Avatar
Dealer : Fred Anderson Toyota of Raleigh
2002 Toyota Tundra LE 4x4 TRD
Sigr6's Photo Albums
Last Online: 08-31-2008 10:14 PM
Sigr6 is on a distinguished road.
Default Re: Fire causing Engine to fall Apart?
damaged valves possibly from the timing belt breaking?
Old 03-20-2008, 10:15 PM
1995 Toyota Camry
Oh I forgot to mention, it is a non-interfering engine. So, the timing belt shouldn't have caused any other damage.
Old 03-20-2008, 10:38 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Hi Volt's Photo Albums
Last Online: Yesterday 06:20 PM
Hi Volt is on a distinguished road.
Check for damaged wiring
Old 03-21-2008, 11:57 AM
1995 Toyota Camry
Hmm..I replaced any visible damaged wires, but it only made things worse. Any other ideas?
Old 03-21-2008, 11:05 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
kathyricks's Photo Albums
Last Online: 07-26-2008 11:33 PM
Was the throttle position sensor exposed to the fire?
Old 03-27-2008, 09:55 AM
1995 Toyota Camry
It's fixed now. It was the coil. Thanks everyone.
