Got the Tundra back just now. I got the phone call this morning, service rep said they found the leak, [we] were right, it was the rear main seal. Here's what my invoice reads:
A CUSTOMER STATES THERE IS AN OIL LEAK, AND TO CHECK BY THE REAR MAIN SEAL
CAUSE: CUST STATES OIL LEAK, FOUND REAR MAIN SEAL WRINKLED, R&R REAR MAIN
SEAL Z TIME FOR RESEAL OF MOUNTING PLATE & DRILL & TAP 3 BROKEN
STUDS
111161 CRNKSHFT REAR OIL SEAL (AM) R&R
2 W
1 90311-A0002 SEAL, TYPE T OIL
2 90080-43036 GASKET, EXHAUST PIPE
1 90917-06083 GASKET, EXHAUST PIPE
3 90080-17187 NUT, LOCK
3 90080-12007 STUD, HEX LOBULAR
1 00295-00103 FIPG OIL PAN
Covered under the 5/60k powertrain warranty, as Mustang said.
It's raining balls here now, so I can't get under and check out the work.
