This is a discussion thread titled "Limited slip differential oil", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-07-2008, 06:06 PM
Dealer : Champion Toyota Scion Gulf Freeway
2004 Toyota Tundra SR5 Double Cab,
- Other - 2005 Honda Civic
thinshavings's Photo Albums
Last Online: 09-06-2008 12:46 PM
thinshavings is on a distinguished road.
Default Limited slip differential oil
Time to change the LSD diff. oil in my '04 2wd DC.
Owners manual says straight 90w synthetic oil.
I can't find straight 90w synthetic oil any where.
What do you guys use??
Old 04-07-2008, 06:33 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
wirelessf's Photo Albums
Last Online: Today 12:47 AM
wirelessf is on a distinguished road.
Default Re: Limited slip differential oil
I currently use Royal Purple 75W90 in my open rear diff. No problems so far.
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Old 04-07-2008, 06:37 PM
Dealer : Rountree Toyota Scion
FLTundra06's Photo Albums
Last Online: 11-05-2008 11:56 AM
FLTundra06 is on a distinguished road.
Many post on here about that and no one seems to agree. I have the 06 DC with the LSD and the book says 90w or 80w-90 but nothing about synthetic for the LSD. It does say Hypoid gear oil API GL-5 and list SAE 90 for above -18 and sae 80w or 80w-90 for below-18 for the LS rear differential. For the standard differential it say Synthetic oil SAE 75w-140 but does not say anything about Sythetic for the LSD. Thats the book on my 2006 Tundra DC. If you have your owners manual look at it and go with what it says, make sure of the API Gl-5 if thats what the book on the 04 calls for. I know a lot of people use Mobile 1 and others Royal Purple. Some have to add additional additive and others don't. I didn't and used the 80w-90 for my LSD and have had no problems in the 2k miles since I changed it.
Old 04-07-2008, 06:52 PM
Did you go with synthetic or regular oil??
Old 04-07-2008, 07:00 PM
Regular gear oil with the API GL-5 rating. I am sure either is fine as long as it has the aditive for the LSD.
Old 04-07-2008, 07:12 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Hi Volt's Photo Albums
Last Online: 11-20-2008 08:56 PM
Hi Volt is on a distinguished road.
I have used Castrol Syntec 75w90 in my LSDs ( all Toyotas ) for the past 15 years with no issues. But regardless of what oil you use, remember to add a bottle of LSD additive to reduce clutch chatter. I use the AC Delco brand additive as it is easily available where I am, but there are others out there from Redline or Royal Purple for example. Some gear oils have the additive already added so you may also check for this.
Old 04-07-2008, 07:17 PM
Let me correct myself the 80w-90 was sythetic that I used. As I said before just make sure it is GL-5 rated and it will have the additive you need for the LSD already in it.
Old 04-07-2008, 07:32 PM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
sr5mike's Photo Albums
Last Online: Yesterday 11:39 PM
sr5mike is on a distinguished road.
what other toyota have you had that had a LSD ? As far as I know the 02 tundra was the first. when I got mine changed at 15K they didnt even have gear oil for it.
At least they have circled the problem.
Old 04-07-2008, 10:56 PM
Dealer : Toyota of Iowa City
2003 Toyota Tundra
fergyr's Photo Albums
Last Online: 11-16-2008 06:49 PM
fergyr is on a distinguished road.
You might want to consider Amsoil. I did the rear diff, front diff and xfer case last fall and used the Amsoil product. Thier web site is very infomative, right down to the quantites that you'll need in each assy. I believe if you search here you can find additional info. I added some lsd rear diff additive and haven't had any problems. Used 4x4 a ton this winter, the drive train seemed quieter in with the Amsoil.
Old 04-07-2008, 11:03 PM
BAD BONEZ BJ's Avatar
Click Username, View Profile!
Dealer : Priority Toyota
1993 Toyota Truck,
2006 Toyota Sienna XLE in Pear White,
2003 Toyota Tundra AC Limited 4WD,
1998 Toyota 4Runner Trade-In,
2004 Toyota Sienna Trade-In,
2004 Toyota Prius Trade-In,
2006 Toyota Highlander HV Trade-In,
1998 Toyota Celica Sold,
- Other - '81 Tercel - Sold
My eBay BAD BONEZ BJ's Photo Albums
Last Online: Yesterday 10:27 PM
BAD BONEZ BJ will become famous soon enough.
Send a message via AIM to BAD BONEZ BJ
Royal Purple 75W-90 in rear LSD diff, transfer case, and will soon change the front diff to RP.
BJ
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages, Black Onyx 202-rebadged. was stock 31K on 5/9/05, now 56K
Performance:
* UNICHIP (broken) * AEM Brute Force Intake * AEM DryFlow Filter * K&N DryCharger * AirRaid TBS * JBA Titanium-Ceramic Headers * JBA Y-Pipe * Gibson CAT-Back Dual Extreme Exhaust * PulseStar Pulse Plugs * Fitch Fuel Catalyst System * Optima D35 Yellow Top * Argus Battery Bug * Fumoto F103N Oil Drain Valve * RP Oils *
Exterior:
* Extang Full-Tilt Tonneau * Bedrug * Topline Tailgate Step * Mr. Gille Upper & Lower Billet Grille * WAAG Bumper Guards, front & rear * HT Side Step Nerf Bars * AVS Hood Protector * WeatherTech Vent Shades * JDM Black Taillights * TurnSmart Solar-power Mirror Turn-Signals * Altec 48" Line-of-Fire LED Light Kit * Altec 53" Screamer Amber Side Marker LED * PIAA Backup/Work Lights * 35 % Tinting * Bully LED Third Brake/Cargo Light *
Interior:
* Gentex Auto Dimming Compass/Temp Rear View * Garmin's Nuvi 660 GPS * Scan Guage II * Passport SR7 Radar/laser shifter * Passport G-Timer GT2 * P.I.E. Adapter
Wheels/Tires:
* Moto Metal M0951 Gloss Black 17 in. Alloys * SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
* Bilstein HD Shocks, F&R * Hellwig Rear Sway Bar & Helper Springs * TCS Poly Steering Rack Bushings * Wheeler's Front Sway Bar Bushings * Timbren SES Kit, Front & Rear *
Brakes:
* TRD Big Brake Kit (front) *
BAD BONEZ BJ
Old 04-08-2008, 10:48 AM
Dealer : Toyota of Knoxville
2002 Toyota Tundra
a049701's Photo Albums
Last Online: 09-13-2008 08:30 PM
a049701 is on a distinguished road.
I would not use the synthetic in LSD. I put synthetic in mine because I thought it would be better and it caused some slippage. Changed it back to the regular oil for LSD and slippage disappeared after the second change (I flushed it and drove a couple miles). I am using LUCAS oil for LSD now with no problems.
Old 04-13-2008, 03:05 PM
Dealer : Hoover Toyota Scion
2002 Toyota Tundra
Lockjaw's Photo Albums
Last Online: 07-22-2008 11:54 PM
Lockjaw is on a distinguished road.
I have Mobil 1 Synthetic in mine, with LS additive. 100K miles with no issues.
2002 Tundra SR5, TRD Off-Road with Limited Slip
Dynomax Super Turbo Exhaust, K&N Panel Filter
Old 04-13-2008, 08:47 PM
05_GTO's Avatar
Dealer : Mic Mac Motors
- Other -
05_GTO's Photo Albums
Last Online: 09-01-2008 01:47 PM
05_GTO is on a distinguished road.
I prefer to use Torco RGO fluid.
Old 04-20-2008, 09:30 PM
Hi Volt's Avatar
I have an original '80 4X4 that I put an Auburn LSD unit in about 15 years ago. My '01 has a TRD (400lb Eaton) unit that I installed last year. Gear oil for LSD units is nothing new, just maybe your dealership.
Old 04-22-2008, 10:32 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Yesterday 11:16 PM
HOGWILD will become famous soon enough.
I have been chasing a power steering growl for a few weeks now and dealer changed the rear gear lube to 80W90 Dino and added friction modifiers and all the growling has gone away!! I had just done my 30K mile diff service with 75W90 Mobil 1 Synthetic and all they had to do was drain out enough to add the friction modifiers but instead they just changed it to Spec! 80W90 is impossible to find around here and i called Mobil Oil before i changed it to Mobil 1 Syn,and they told me no problem it has enough addatives to not cause any growling. Well it was growling so hard it sounded like the power steering was goin out! I would still use Mobil 1 Synthetic in the rear diff but on an LSD rear diff i would put 2 to 6% modifier with the Mobil 1!! I like to learn the hard way i guess!! was not a small chatter it was a continual growl like pump burnt up sound was coming from rt front side of truck but they finally got me going and soo much quieter!! Guess i will call Mobil Oil tomorrow and see what they will say?
Torco sells an addative just for Toyotas and i think it's the "F" version of their modifiers! I got an email from them and they said it would be no issue using it at all! so 60K service i will try Mobil 1 again with some Torco "F" modifier!!
