This is a discussion thread titled " Installed a Spintech Sportsman muffler (review)", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-10-2003, 09:54 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Default Installed a Spintech Sportsman muffler (review)
This past Saturday I installed a Spintech Sportsman XL muffler in place of the factory muffler. I wanted a little throatier sound and a little more power and mileage wouldn't hurt either. I bought a 2-1/2” center inlet and 2-1/2” side exit and installed it myself.
The sound summed up in one word is awesome! It's the perfect compromise between all out obnoxiously loud and factory quiet. It has a deep mellow sound at idle that can barely be heard from inside the cabin. I expected it to be louder when I first started it up. It sounds most like a muted Borla at idle, very deep and mellow but it’s still distinct.
I've had the TRD dual exhaust before so I'll compare it to that. It's quieter or about as quiet as the TRD at idle but when you get on it, it becomes louder and sounds way better. It doesn't drone nearly as bad at 2000 rpm like the TRD dual exhaust did. During normal driving under 2500 rpm it produces a gratifying deep throaty sound that is just perfect. Not too loud and not too quiet. When you give it a lot of throttle like accelerating up a highway on-ramp it gets really loud under 2500 RPM, then starts to wail at 3000 rpm and really wails above that producing the most awesome sound I think you could get from this engine. On the highway you can hardly hear it at a 65-70 mph cruise and light throttle, which is perfect and there is no drone.
As far as power is concerned I can't really say until I put it on the Dyno March 29th. The but-O-meter as many of you know is highly inaccurate. I think there might be a small power increase but we'll see. If anything there is no difference for now.
Cost was only $99 + $5 for a short 2-3/8 pipe as an adaptor to make it fit the 2-1/4” stock pipe.
Soon to come I will cut the stock muffler in half so that TS members can see what it looks like inside. We’ll see just how restrictive this muffler is!
Here is a picture of the Spintech muffler painted black. It's built like a tank. The quality is first rate.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 03-10-2003, 09:55 PM
v8Toilet's Avatar
stock muffler
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 03-11-2003, 08:15 PM
03TundraTRD's Avatar
Last Online: 03-15-2007 08:11 PM
03TundraTRD is on a distinguished road.
03TundraTRD's Photo Albums
Hey v8Toilet do you know if I can use the sport truck SUV muffler
or the sportman street mufflers with the hiflow cats I have a 2003 V6
Old 03-11-2003, 08:57 PM
v8Toilet's Avatar
I don't see why not! All you have to do is go to their website @ http://www.spintechmufflers.com and look up the muffler that best matches the size of the stock mufflers length, order it, and then have a muffler fabrication shop cut out the old and install the Spintech. You could also do it yourself but if I had to do it again I would just have someone else do it. If you can get a 2.25" inlet diameter and 2.25" outlet diameter than get it and if not than get the next size up. The stock pipe size is 2.25" on the v8 engine. Don’t get a dual outlet muffler; I feel the singe outlet will give you just as much power without hurting low-end torque, which is important in a pickup truck. It also makes everyday normal driving more gratifying when you have good low-end torque.
Funny thing is I spent way more money for the TRD dual exhaust and lost my low-end torque so much so I couldn’t spin the dam tires even in a turn. The TRD exhaust didn’t sound as good in my opinion and droned at 2000 rpm on the highway.
They sell the aluminized Spintech muffler for around $99 each and the stainless steel muffler for about $80 more or $180.
By the way since I reset the computer and added the TRD filter I think there has definitely been an increase in power especially in low end and the midrange.
I don't think you need high flow catalytic converters! I've seen tests in Hot Rod magazine where OEM GM converters out flowed so called high flow aftermarket converters. Changing over the like new stock converters is a waste of money in my opinion and won't net you anything or very little.
I think the biggest restrictions in the exhaust are the exhaust manifolds and the muffler.
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 03-11-2003, 10:10 PM
fastmhz's Avatar
Dealer : Elmore Toyota Scion
2000 Toyota Tundra,
2005 Toyota 4Runner
Last Online: 01-02-2009 06:14 PM
fastmhz is on a distinguished road.
Send a message via AIM to fastmhz fastmhz's Photo Albums
I'm glad you like the sound and power!
Doesn't it sound like a muscle car?
Old 03-11-2003, 10:20 PM
v8Toilet's Avatar
O-yeah!
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 03-12-2003, 02:13 PM
awesometundra's Avatar
Dealer : Reno Toyota
2002 Toyota Tundra
Last Online: 09-06-2008 07:12 AM
awesometundra is on a distinguished road.
Send a message via AIM to awesometundra awesometundra's Photo Albums
Question
What is the part number you ordered?
http://www.spintechmufflers.com/spin...et&category=15
Old 03-12-2003, 03:56 PM
v8Toilet's Avatar
#3332XL but it's 2.5" in and 2.5 inch out.
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 03-12-2003, 08:20 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
The size of the muffler relates to the sound level. Spintech's big "Truck RV" muffler will be quieter, and their "Sportsmen Street" muffler will be louder.
Ken
Old 03-13-2003, 06:06 PM
What is the stock diameter piping on a V6 and would I benifit if I go with 2 1/2 inch Diameter pipes
Old 03-12-2008, 03:49 PM
Tundra Guy's Avatar
Dealer : Avondale Toyota Scion
2006 Toyota Tundra,
2001 Toyota 4Runner SE with Moon Roof
Last Online: 12-31-2008 08:34 PM
Tundra Guy is on a distinguished road.
Send a message via ICQ to Tundra Guy Send a message via AIM to Tundra Guy Tundra Guy's Photo Albums
Default Re: Installed a Spintech Sportsman muffler (review)
I noticed some have stated the stock 4.7L V8 Tundra pipes were 2.25 inch, but others have stated 2.5 inch (and did not mention the mis-fit issue). Also, virtually all aftermarket cat-back kits for this engine are either 2.5 or 3.0 inches - adding to my confusion. And, obviously, you had to use adapters to go down from 2.5 to 2.25 inches during install, so I am "befuzzled". For the 4.7L V8 Tundra (2000-2006) are there varying stock pipe diameters by year, or what? Some posts have stated they used the SpinTech PN 3333 which is 2.5 inches in and out. You stated you used the 3332XL which is also 2.5 in and out- but had to reduce to install it. SpinTech's brochure shows the 3222 and 3222XL (as well as others) with 2.25 inch pipes, but no one has ever mentioned using any SpinTech muffler part numbers that are 2.25 inches in the forum (that I have seen, anyway), which seems odd. Still, the prevailing citations still indicate a 2.25 inch stock piping. Before I spend my money, is there any reason why I would not want to buy a SpinTech with 2.25 inch pipes, if that is the required direct fit solution? Can anyone shed some additional light on this subject before I buy the wrong muffler inlet size? I am wondering if this is a O.D. vs. I.D. issue? Any help is appreciated. Thanks to all on this great forum.
"Modern computers allow mankind to create and propagate errors at a rate of millions of times per second. We can now screw things up faster than the human mind could ever possibly comprehend!!!!"
-- Jimmy the Tundra Guy
Old 03-12-2008, 07:04 PM
jamesjr4750's Avatar
Dealer : Rodland Toyota Scion
2003 Toyota Tundra
Last Online: Yesterday 10:51 PM
jamesjr4750 is on a distinguished road.
jamesjr4750's Photo Albums
I just got the 2.5" IN/OUT size Sportsman XL and then had the shop use the 2.25" stock pipe using lots of welding stick to fill it the gaps then doing a nice seal all around. Can't remember what model I got but its the 2.5" size. Get them to take off the resonator too and replace with stock piping diameter in place there (I think mine could be louder/nastier without the resonator on: Others have said so too on previous threads).
Last.. Get their 304 Stainless Steel version directly from Spintech. Mine was twice as much in price as the Mild Steel they regularly use. It will hold up better.
03' Access Cab Toyota Tundra V-8 4.7L, 4x4
305/70/16 BFG Muds on 4" B/S Wheelers' Offroad Steel Rims
Donahoe Racing Coilovers (cranked 2.5")
Total Chaos Upper Control Arms and Rack Bushings.
Bilstien 5100 rears'
ARB Sahara Bumper with Fog Light Kit and KC SlimLites in Front
Old 12-26-2008, 01:41 AM
808fireman's Avatar
Dealer : Windward Toyota
2008 Toyota Sequoia
Last Online: 01-05-2009 08:03 PM
808fireman is on a distinguished road.
808fireman's Photo Albums
just installed one in my 08 sequoia. didnt want it too loud but wanted to know it was there. this is the perfect exhaust just what i wanted and man does it howl when you get on it.
808fireman
08 Sequoia 4x2
spintech exhaust
volant cai
Bookmarks
