You can go out and have lunch for the time it takes to fill that transmssion through that weenie filler tube. Don't recommend synthetic because it doesn't let you know if you're abusing the transmission. Synthetic's are great in everything else. I use it in my Diff and engine. Don't forget to change that fluid every twenty or so thousand miles. Only the four quart change is necessary if not discolored. That transmission can out originally as a A40 and has been modified since to a four speed and electronics. I think it's alittle soft on the size but, so far it's been holding up pretty good.
