This is a discussion thread titled "Changing Oil Viscosity", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-12-2003, 01:07 PM
cdalton's Avatar
Dealer : O'Brien Toyota
2003 Toyota Tundra
Last Online: 07-25-2006 05:01 PM
cdalton is on a distinguished road.
cdalton's Photo Albums
Default Changing Oil Viscosity
I have a new 2003 w/V8 and I pull a boat (23 foot runabout) in the summer for 3 hour trips out of overdrive (high rpm's). I am contemplating changing to Mobil 1 10W30 for this reason in the summer and then changing back to 5W30 in winter. Does anybody know if it is a problem switching viscosities or should I just stick to 10W30 year round. I'm in Indianapolis and it gets down to 0 degrees but not often. Also I think 5W30 is to light of oil for a V8 anyway even without towing. Anybody have any advice?
Old 03-12-2003, 03:50 PM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
I would always run the 10W30. Gas mileage differences are nil but the wear is probably less with the thicker oil.
Old 03-12-2003, 08:27 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Both oils are 30 wt @ 100°C...but, the 5W-30 may be more prone to losing viscosity through a process know as shearing. The "viscosity index improver" polymers get mechanically damaged and the result is lower viscosity after a couple of thousand miles. I'd stick to 10W-30 in the summer. There is no problem with changing viscosity as the climate changes. In fact, it is a very good idea. With your hot summers and the weight of your boat, do consider using an API-SL 15W-40 oil, even though it's not listed in your owner's manual.
Mobil 1 is a thin 30 wt. The range for 30 wt. is 9.3 to 12.4 cSt @ 100°C (http://www.chevron.com/prodserv/NewO...y_motoroil.htm ) and Mobil 1 comes in on the low side (https://dallnd6.dal.mobil.com/GIS/Mo...0?OpenDocument )
Mobil 1 is an excellent oil. If you can find a retail source for Schaeffer #703 10W-30 or #700 15W-40 in your area ((800) 325-9962), you'll find that it's cheaper and gives equal protection as M 1.
http://www.schaefferoil.com/data/703.htm
http://www.schaefferoil.com/data/700.htm
In some ways, the Schaeffer oil may give better protection. The Mobil 1 xW-30 carries the European rating of ACEA A1 (lowest) and the Schaeffer xW-30 carries the rating of A3 (highest) especially with better High Temperature/High Shear ratings.
http://www.acea.be/ACEA/20020618Publ...lSequences.pdf Page 4 &5
Ken
Old 03-12-2003, 11:48 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
I run the Mobil 1 5W-30 in the winter, and the 10W-30 in the summer here.
You 've got an '03 so im not sure that you have the tranny cooler mounted in front of the radiator or not. If you don't you might be better off running EITHER oil and adding that extra tranny cooler.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 03-14-2003, 12:50 PM
acme's Avatar
Dealer : Northridge Toyota
2003 Toyota Tundra
Last Online: 11-19-2008 03:58 PM
acme is on a distinguished road.
acme's Photo Albums
I run 0-40 Mobil 1 . It can be used in place of 0-30 or 5-30 and is rated " Energy Conserving" and withstands high shear and heat in the summer. Also ok for winter.
From Mobil 1 :
..Mobil 1 with SuperSynTM 0W-40 is formulated for newer European cars, especially those with advanced-technology, multi-valve engines. It can be used where an SAE 0W-40, 0W-30, 5W-30 or 5W-40 grade viscosity is recommended.
alan
2003 Tundra
Bookmarks
