This is a discussion thread titled "Does warming up your truck help to overcome water condensation in oil?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-17-2008, 06:39 AM
simon barsinister's Avatar
Guest
Dealer : Expressway Toyota
2002 Toyota Tundra
Last Online: 04-22-2008 03:54 PM
simon barsinister is on a distinguished road.
simon barsinister's Photo Albums
Default Does warming up your truck help to overcome water condensation in oil?
Wanted to ask anyone knowledgable about the tundra v8 engines whether letting your car warm up (~10 minutes) in sub-freezing temps helps to overcome water condensation problems in your oil when you are only a 3 mile drive to work in the morning?
I know driving longer distances helps the best, but I can't justify driving 7 extra miles in the morning and racking up my mileage when I'm so close to work. I also change my oil every 3K, so I don't know if changing my oil even more often is my only solution or possibly switching to a synthetic blend oil with more additives would help to minimize sludge buildup from the moisture.
Any other thoughts on helping to rid moisture would be helpful. Thanks.
Old 04-17-2008, 10:36 AM
Dealer : Courtesy Toyota
2003 Toyota Tundra
Last Online: Yesterday 03:46 PM
ericb is on a distinguished road.
ericb's Photo Albums
Default Re: Does warming up your truck help to overcome water condensation in oil?
Driving is the quickest way to warm the engine. The 10 minutes of idling could be better served by an extra 5 minutes of driving. I think a weekly trip of 15-20 miles may be enough to burn off the condensation from your daily commute. Your type of driving is, interestingly, called "extreme or severe" conditions.
As for oil changes, I'd think a synthetic could extend your interval to 5k. You could also have an analysis done of your current oil at 3k to see what they find. BTW, my wife used to do a 3 mile commute in her Subaru and I did 5k oil changes with synthetic and no problems.
2003 Tundra Access Cab SR5 V8 4X4
RAPS, C.R. Lawrence Slider Rear Window from Yipes!, Hellwig Rear Anti-sway Bar, ASA TRS alloys, 265/70-16 Firestone Destination AT tires, debadged doors, ARE MX series cap, WeatherTech front floor mats, Scanguage II gauge & code scanner
Old 04-17-2008, 09:05 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: Yesterday 04:11 PM
kathyricks's Photo Albums
Idling the engine for 10 minutes and then driving only 3 miles is the worst possible scenario for causing water buildup in your engine oil. The only solution, besides driving a longer route to work, is to change your oil once a month during the winter with dino oil to get rid of the water in the oil. Synthetic won't do a thing to stop the rusting of internal engine parts exposed to the water in your oil.
Old 04-18-2008, 09:03 AM
Guest
2002 Toyota Tundra
I thought the additives in synthetic help to suspend contaminants like water and prevent the formation of sludge to some extent. Am I incorrect?
Old 04-19-2008, 05:00 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
Last Online: Today 12:18 AM
wirelessf is on a distinguished road.
wirelessf's Photo Albums
Don't forget about the differential.
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Bookmarks
