This is a discussion thread titled "TRD Supercharger PSI", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
is the one that should be on there - changing it is not easy and voilds the warranty. Going smaller would most likley generate more heat that would undercut any gains in boost.
Also - your exhaust system affects boost - the more free flow, the less back pressure => less boost, but more power.
Originally posted by Dan T is the one that should be on there - changing it is not easy and voilds the warranty. Going smaller would most likley generate more heat that would undercut any gains in boost.
I know all of what you said . But my question is Does the Supercharger kit come with a 7psi pulley or higher ???
i've been told that if u go with a smaller pully on the trd s/c u will get belt slippidge. the pully on the unit is 2 inch. and i'v also been told (from a realiable sorce) that the s/c boosts abought 3/4 lb more than it regiters on the boost gadge, do to where the tapping is on the s/c fyi petros
I beleive the road to riches here is the crank pulley...just how big is up for debate. The 5.9 is the one I would want.
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
It comes with only one pulley for all years(4.7l), suppose to give 7 psi @ sea level. The v6 s/c was available with different pulley's...more boost for higher altitude.
8psi is 8 pounds of air pressure per square inch. The stock pulley is 2". If you go smaller on the S/C pulley, then there is not enough surface area for the belt and with the higher boost = more resistance on the S/C pulley with LESS surface area = SQUEEEEEEEEEEEEL.... belt slippage. THE ONLY way to achieve more boost than stock is a larger crank pulley. Ford Lightning, and many others do this, so it is not unique here. It is a tried and true way of getting more boost.
Lastly, the stock S/C pulley is pressed on, it can be removed, but it is a major PITA... so... larger CP is what I am doing!
SCDTRD
__________________ The Beast: 1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
Just curious what are you guys intake temps when you increase boost on the 4.7. I had the 3.4 kit and was amazed at the amount of heat that blower made. I was consistantly over 200 degree intake temps at 6 psi on a bone stock engine in my 4runner.
