This is a discussion thread titled "Spark Plug Question", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-27-2008, 01:09 AM
lelandstanford's Avatar
2005 Toyota Tacoma
Last Online: Yesterday 06:06 PM
lelandstanford is on a distinguished road.
lelandstanford's Photo Albums
Default Spark Plug Question
The brown/orange color discoloration on the upper porcelain insulator (where brand and p/n is). Is it an indication of any problem (assuming everything else is normal)?
2005 Tacoma AC 2WD 2.7L 5M
Old 05-27-2008, 11:24 AM
kovawa's Avatar
Dealer : Toyota of Orange
2006 Toyota Tundra,
1996 Toyota 4Runner,
- Other - 83 porsche 928S
Last Online: Yesterday 02:34 PM
kovawa is on a distinguished road.
kovawa's Photo Albums
Default Re: Spark Plug Question
No problem. I've changed out zillions of plugs that looked like that.
Old 05-27-2008, 12:30 PM
2005 Toyota Tacoma
What caused the discoloration?
Old 05-27-2008, 01:59 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 06:26 PM
HOGWILD will become famous soon enough. HOGWILD will become famous soon enough.
HOGWILD's Photo Albums
are they both the same heat range plug? looks like boot just stained insulator? was boot hard to come off or melted a tad on the end where it's discolored? plug on the rt looks like it might not be specd for truck or is the left one OEM? also center electrode worn bad on one side on the rt plug.
Old 05-27-2008, 05:39 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra V8 AC,
- Other -
Last Online: Yesterday 07:02 PM
Tones is on a distinguished road.
Tones's Photo Albums
How many miles? Looks like its been in there a while judging from the gap(?).
Old 05-27-2008, 11:25 PM
2005 Toyota Tacoma
Plugs in the pic are not from my truck. It's only an example.
More than often, when I replace a slightly worn and discolored plug (w/ correct gap) w/ a new replacement. The throttle response improves slightly.
Is the upper insulator degrading?
Old 05-28-2008, 03:22 AM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: Yesterday 09:55 PM
Hi Volt is on a distinguished road.
Hi Volt's Photo Albums
This discoloration is caused by compression leakage blowing carbon past the shrink seal between the porcelain and the steel ( during plug production, the steel is heated then pressed around the porcelain, upon cooling the steel shrinks for a tighter seal). What you are seeing is carbon deposited on the insulator. The band stops where the boot seals. Most likely you will see carbon on the bottom of the boot as well. Turbo/Super charged engines make this problem worse as there is more cylinder pressure. It is common for the specified plugs for these engine types to be specially designed and have better sealing properties. I use the Denso OE plugs myself and rarely see leakage, and if so, only one or two plugs from a set. NGK plugs are not bad for sealing either.
If you see the carbon band extend upward into the boot, inspect/clean or replace the boot as carbon is conductive and can eventually cause spark leakage down the inside of the boot resulting in boot damage and misfire.
Old 05-28-2008, 09:49 AM
2005 Toyota Tacoma
Thanks Hi_Volt for the explanation.
Bookmarks
