This is a discussion thread titled "Engine Stalling When Shifting Into Drive", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
2001 Sequoia Stalling
I Have A 2001 Sequoia That Is Stalling When You Try To Drive Off From A Start. My Transmission Performs Good In All Gears With A Full Transmission Fluid Level Nice And Red,,not Burnt. The Throttle Performs When You Give It Gas In Neutral And Park. But When Placed In Drive To Start Off At The Light The Engine Dies Unless You Really Give It The Gas And Wen Coming To A Stop At The Light. Can Anyone Give Me Advise On What The Cause Is? I Cleaned The Throttle Body, Changed Air Filter, Sparkplugs Are Clean Burning, And When I Took The Mass Airflow Sensor Off To Clean It Still Had The Diodes Intact, Is There Any Way If Maby It Is The Problem To Test The Throttle Body Sensor? No Engine Check Light Is On. Any Help Would Be Greatly Appreciated. Thanks, Neil In Hickory, N.c
__________________ 2004 Salsa Red Pearl DC Limited 4x2
Toyota Mods:
Accessory Meter / Leather / LSD / Moonroof / Tow Package / Rear DVD System / 6 Disc Changer / Challenger Step Boards / Carpet Mats / Toyoguard
My Mods:
Debadged / Line-X / Window Tint to Match Rears / Hellwig Anti-Sway Bar / ORW Steering Rack Bushings / RAPS / VSE Subwoofer / USA SPEC iPod Adapter / Pop&Lock Power Tailgate Lock / Unichip / JBA's are back on / Gibson Exhaust
If it turns out to be the converter send it to that import trans place in Jesey that does the valve body modifications. i cant think of the name of them. They can rebuild your stock converter and improve it for less than a new one. If memory serves correct its about 479 for a complete job and im guessing the stock one is about that.
Thanks for all of the responces guys, after taking it to toyota it was the transmission. Had to replace, $2300.00. Oh well, on down the road I go, but seriously guys thank you.
