This is a discussion thread titled "Has anyone installed TRD LSD on a 01' tundra??", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-26-2003, 10:08 AM
deadeye01's Avatar
Dealer : Harrelson Toyota
Last Online: 12-18-2007 01:37 PM
deadeye01 is on a distinguished road.
deadeye01's Photo Albums
Default Has anyone installed TRD LSD on a 01' tundra??
I was thinking about putting a LSD in the rear of my 01' tundra. Its a 4x4 ltd with the v8. How difficult was this project? Is it a do it yourselfer or do I need to take my truck into the stealership? Thanks Matt
Old 03-27-2003, 01:44 AM
VanityPlates's Avatar
Dealer : Rockingham Toyota
Last Online: 12-22-2008 02:57 PM
VanityPlates is on a distinguished road.
VanityPlates's Photo Albums
Unless you are a mechanic, I would have the dealer do it.
Should cost aprox 684 for LSD, 300 for labor and a couple dollars for fluids.
It would be covered for the remainder of your warranty.
Old 03-27-2003, 11:52 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim will become famous soon enough.
dyogim's Photo Albums
It shouldn't be too hard to do as long as you have the right tools. Go to www.toy4x4.net and check out the Lock Right Locker install on the Tundra. This was my tundra that Mike Ross and I did. We completed it in about 3 hours. I though it was going to be difficult. However, after doing it, I could do it again. If you plan on tackling the job, make sure you keep everything organized and left/right side oriented, specifically the shims.
Mike
Mike - http://dyogim.blogspot.com
Old 04-15-2003, 10:15 AM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica
Last Online: Yesterday 10:07 PM
Herbicidal is on a distinguished road.
Herbicidal's Photo Albums
Default More info...
I realize I am coming into this thread somewhat late, but a buddy of mine bought and installed the TRD LSD and it is a complete unit! You "simply" replace the rear diff. with the TRD LSD one. I can't quite remember if there is a "core" charge involved, but I think there is.
Herbicidal
My daily driver - 2008 Yaris sedan 'S'. Tinted windows in the rear, TRD anti-sway bar for the rear, 17" rims - Samurai SC02 Hyper Black. TRD lowering springs.
My favorite ride - a 2001 SR5 4x4. With - RCD 6" lift, JBA Titanium coated headers, JBA y-pipe, Unichip PnP, ARB rd-129 air locker (rear), Camburg UCA's, custom front Sway-A-Way coilovers, custom Sway-A-Way's with remote reservoirs and billet mounts for the hind-quarters, PolyPerformance limit straps with adjustable clevis's - mounts welded up by AJ at BentUp.com, Stubbs Welding rock sliders and custom front skid plate, 315/75/16 Toyo Open Country M/T's, on all 4 corners wrapped around 16x8 MB Motoring Blitz rims, cryo'd 4.88's set up by Inchworm Gear, Trenz billet grill upper, T-Rex billet grill lower, on board VI-AIR aircompressor and 3 gallon air tank from Wheelers Off-Road, Inc, AutoMeter A-pillar pod with transmission temp gauge (sending unit in the tranny pan), Long Tru-Cool LPD tranny cooler, 10" Flex-a-Lite tranny cooler fan w/thermostat, TRD billet oil filler cap, TRD air filter, TRD dual exhaust, and TRD add-a-leaf rear springs. Superlift TruSpeed Speedometer Recalibrator. Warn Trans4mer Grill Guard, brush guard and 9.5ti winch w/cover. Budbuilt traction bar. Wheelers Off Road Centric performance brake rotors: cross-drilled and slotted. Staun tyre deflators set for 13 psi. Our home away from home, 2004 Outback 26RS travel trailer with 15" MB Motoring Blitz rims to match the Tundra.
Old 03-19-2007, 11:19 AM
jess'toy's Avatar
Dealer : Deal & Davie Toyota
2000 Toyota Tundra,
2007 Toyota Tundra Pyrite Micah 4x4
Last Online: 04-14-2008 10:36 PM
jess'toy is on a distinguished road.
jess'toy's Photo Albums
Default Re: Has anyone installed TRD LSD on a 01' tundra??
Are the 2000 and 2001's different rearends?
Jess'toy
'07 Tundra SR5 DC 4x4
5.7L, Pyrite Micah, Black and gray leather
BU,CK,DS,FE,MG,NV,OF,SO,TM,28,37,CJ,CT,RB,SO
'If you aint gonna do it right then leave it for someone that will"
Old 03-19-2007, 11:53 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
No. All tundras through 1999-2006 use the same 210mm(8.25") rearend.
Old 03-19-2007, 12:24 PM
jess'toy's Avatar
2000 Toyota Tundra,
When my gears were done I bought the lsd from a dealer that was advertising them on the forum for $299.00 (TRD). It involves pulling the whole carrier with the ring gear, replacing the carrier and reinstalling. If you don't change gear ratios you wont have to touch the pinion. Be sure and measure the backlash on the gears before removal and reinstall EXACTLY the same. I think you could do it yourself with a dial indicator and a good bearing puller. If you are changing ratios I would leave it for a pro. Messing with used gears can be a disaster if they don't go back together just exactly the way they wore in to one another. Last time I did any myself I used white lithium grease to check the smear pattern. Don't know if that procedure has been replaced with a better method or not.
I've got a great idea that will save you alot of hassle! Just fly out here and buy my wrecked '00, drive it home, it'll be a little drafty and real ugly, then swap out the whole front and rear ends with the suspension tires and wheels. That would keep you busy for a day or two. Swap the engine too and your truck will scream!
Jess'toy
Old 03-20-2007, 05:07 PM
2002toytundra's Avatar
Dealer : Jim Norton Toyota
2002 Toyota Tundra Black SR5 2WD Access
Last Online: 01-02-2009 12:00 AM
2002toytundra is on a distinguished road.
2002toytundra's Photo Albums
I put the Kazuma TRD LSD in my 2002 and it is the best money I have spent. performanceproducts4trucks.com has the LSD for $275.00. I took it to the dealers in the area and they were unable (did not want to) intall it since the carrier and gears are reused. I took it to a differential shop and they installed for $350.00 out the door. THe Kazuma's clutch packs are tensioned to 400 foot pounds so you get that much more traction.
There is the option of swapping the entire third member (core charge included) and you get the regular TRD LSD, the packs are tensioned to 200 foot pounds. Either way you better know what you are doing, not really for the shadetree mechanic.
Bookmarks
