Re: P0420 CEL does not mean cat is bad on a V-6
It has done this for the past 4 years. The California V-6 has a Air/Fuel front sensor and a O2sensor after the second cat. I have replaced the A/F sensor and will wait until the rear throws the dead O2 sensor. The second sensor is not involved with the closed loop function, just a check of the second cat so not a performance or pollution issue. I just wanted to post this because over the years I have seen quite a few post that they got this code and had to replace the first cat and the toyota price is over 1000 dollars. Some have done it under warrantee and some not, I would just suggest to get a actual test at the pipe before I believed the code. What is interesting is if the code is not cleared and the vehicle cycled to get a system ready reading, it would not pass smog in California even if it had perfect readings off the pipe.
